Assuming it in a 33..
Your mechanic probably installed it wrong because he doesnt know what he's doing. why would you let him do it if he hasn't got a clue....
can't go past 5psi, probably just running stock actuator pressure.
get your money back and go somewhere else or read the manual, should be fairly straight forward
Well he is a mechanic that's why I'm pretty sure he did install it right just needs to bet set up it does work! Only on 5psi I tried to set it on 10psi and it switches back to 5psi I did read the manual tried to get it going but failed might give a auto electrician a call!
did you check his installation of the solenoid with the manual? its easy to put something in backwards.
the stock actuator is 5psi, so its not working, if it was you'd be getting more.
if you can find someone local who knows anything about boost get them to have a look at it. any car meet or something should find you someone =)
  • Like 1
Ok sklyn thanks for that I have not checked that! I'm assuming mechanics know this shit just to install a boost controller I did ask him if he knows how to install he said yes! Most mechanics should know FML not rocket science but I'll check thanks for that!
Ok should I get auto electrician to check it or a turbo mechanic to check thanks for advice! Nizmo_Man
Not necessarily. Many "professionals" hate to admit what they don't know. Post your location up with your name and see if a local SAU member can have a look at it or they may point you to an RB knowledgeable workshop.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
