Yeah well was dropped off 2nd November and leading up to Xmas said was just snowed under with cars to fix etc, apparently was just a fuel pump to install and AFM at that time  but that was around Xmas when we spoke about it. Why would they want to push a car in and out the workshop daily when it just needs a fuel pump and start it ??
Been an awesome day, the tuner wasn't expecting me to drive it home so we went out for some very basic road tuning to make it drivable.  She's running very rich, so can't put much boost in or it stutters but the thing is very lively, was pulling well without even any boost, gonna be a weapon when tuned. I pulled into a servo to fuel up and some old Indian women in the car opposite, her look was priceless, haha, so disgusted with the sound of the RB haha..
Mod plate and some more fabrications like flexible joint in dump and blow off valve recirc next then a road tune followed by a few runs on dyno to further fine tune things.
  • 3 weeks later...
Been trying to tuck the exhaust up higher, it was 2inch off ground , has to be 100mm at lowest point.  Shes now 75mm front and bout 90mm at middle muffler.  Cant physically go higher cause theres 10mm between middle muffler and the body.. will have to keep raising the coilovers ?.  Im expecting popo pulling me over so want it legal height and mod plated before driving again, i know a guy who can do it so thats next thing..
Edited by AngryRB
Isn't this thing a race car or something?
Why number plates and driving on the road etc?  Put it on the track.  No police.  Solved.
Cut and raise the floor, lift the exhaust.  Solved.
:)  in truth, looking ok.  Just give a few more updates, presume it's actually hit a dyno and you're moving onto the next problem areas to solve.
  • 1 month later...
  • 3 weeks later...
Finally hit the dyno, the 1000cc x spurts at 85% and walbro pump at its limits also so stopping here.  Didn't get chance to play with cam positions and was expecting boost on earlier but it's got plenty of grunt on the street frying the 275's in second.
Edited by AngryRB
  • Like 4
  • 3 weeks later...
Had a big win today, the exhaust although sounded great under boost was droning and too loud in traffic so I made a holmz heltz resonator chamber.  It's maybe working too good as its super quiet now,  who would of thought a big cannon could be quiet and  cost me nothing ?... my welding is super amateur but it works ...
When I get time I'll make a series of different lengths and fine tune it..
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
