We are producing a billet R32-34 upright that should solve pad knock and wheel bearing issues that these cars suffer from when pushed hard with downforce and big tyres. We're just going through the development stage at the moment and they should be ready within a few months.
Attached are some STI/EVO and custom STI (with post mounts) for reference
Anyone interested please get in contact.
post-93639-0-93637800-1459904960_thumb.jpg.
https://www.sau.com.au/forums/topic/464073-r32-34-gtr-billet-front-uprights/
Weight wise there won't be much in it (They are very light standard). We're moving to an R35 bearing which will solve the bearing and pad knock issues. Overall we're not changing geometry as most use aftermarket arms for this. We are looking to simply solve the bearing and pad knock issues with increased stiffness and the new wheel bearing.
  • 3 weeks later...
  • 5 years later...
Do these uprights exist now??
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
