Hi everyone
About to replace spark plugs on R34 GTR.
Car is pretty much stock so was just looking to replace with the stock plugs (I.e. NGK PFR6A-11) but also came across Bosch (8153-6).
Anyone here ever run the Bosch 8153-6 plugs as they are about half the cost of the NGK's?
Thanks
https://www.sau.com.au/forums/topic/464181-spark-plugs-r34-gtr/
If they are listed as a direct replacement then they will be fine. Should be a reference chart on the web somewhere that will tell you.
Yep, try this one:
http://www.angelfire.com/extreme4/skidoolympique/SPARK_PLUG_CROSS_REFERENCE.htm
Says Bosch equivalent is FR8DCX
See line 1257
That's all that's in mine Chris, I plan to just swap them out every service or 2 given how cheap and easy to get they are.
No misfire issues with spitfires and those plugs at 330or so rwkw.
For a street car they'll be fine.
Yep, try this one:
See line 1257
Strange it comes up with FR8DCX. This was the Bosch catalogue page at Supercheap Auto. post-91000-14605255392572_thumb.jpgpost-91000-14605255571854_thumb.jpg
The package for 8153-6 also shows FR6KPP33X+
Not interested in going copper plugs but thanks.
For me it's coppers every time.
I bought mine from here, about $3.00 a shot. Add some filters to the order to reach $50 and it's free delivery.
https://www.sparesbox.com.au/spark-plugs-ignition
But whatever plug you choose, check the protrusion from the head. Give the spring in the coil pack a bit of a tug to make sure it contacts the conductor.
ISO dimension plugs are a bit shorter than "normal".
Hmmm sounds like the coppers are the way to go. Maybe I'll be a convert. Just out of interest, should I just stick with the stock plug gap of 1.1 and heat range of 6? Car is fairly stock with cat back, boost restrictor removed (running 1 bar) and arc induction box.
I was using 7's but fouled a set after only a few k. Probably due to letting the car idle too long with the ac on during the summer. I've recently been running 6's and changing to 7's when tracking. I'll go back to 7's and see what happens. CBF changing plugs all the time.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
