The way the E85 gets chewed up on spirited drives, a drum , 200 odd Lt ( 3.5 tanks ish) would not last much longer than 2 to 6 months if you drive it 3 times a month. Depends on what you call going for a drive is. Either way I doubt you would have a condensation problem.
Just have to wonder when you buy it from the station how old it is before you buy it ?
I was worried about the E85 I bought before I had to put my car in for some work and had it for over 8 months in 20Lt containers , tipped it in and off it went, just have to love those flex fuel sensors :)
"If" I used E85 all of the time 200lt would not last much more than a month or 2 at the most. But it is good to use 98 pump , then run it close to empty and when the 85 goes in you can get the full benefit of the difference :)
If I did not DRIVE the car, I would not even buy E85, it is a pain getting it where I live but it is so much better than 98, see Paul, you win :)
My car is a weekend only 2-3 times driven a month.
I bought some ethanol treatment for condensation so I'm more worried about the safety of transporting a drum full on its side in the back of the Territory.
I also bought and e85 tester so I'll be able to at least see what the content is.
I wasn't planning on removing the drum from the car, the bung is pretty serious so I can't see it leaking when the drum is next to new, it also can't be filled up past the bung anyway when on its side.
When filling jerry cans, its always recommended to put them on the ground, (due to static elec i think) So filling the drum, thats in the back of you're car, nope, would not do. Plus, as above, Its illegal.
Local servo actually has still shots of its camera's of some bloke filling a jerry in the back of his ute, and it catches alight, scary stuff!
From a quick google search, the total fuel you're allowed to carry with a car is 250l, including car's fuel tank, and It has to be mounted outside the car.
http://www.whatsupdownunder.com.au/News/Tips-Hints/Carrying-Extra-Fuel/Jerry-Cans-February-2015
No idea how accurate this is though.
This is funny, mainly because Ethanol/Methanol is the treatment for most moisture issues. There is no way moisture will ever be a problem in a sealed container, and even if by some chance you managed to pour a cup of water into the drum, or left the lid off in a rain storm, the ethanol would quickly absorb the moisture and get rid of it from your tank, rather than letting it sit and rust. That amount of water evenly distributed in the tank would barely change the tune, I doubt an AFR gauge would read the difference.
I have used 2 year old United fuel from a customers car, he was too worried to run it and wanted me to drain the tank for fresh fuel to tune with. I poured it straight into the Evo running 32psi, no issues. AFR's perfect, ethanol percentage within 1% of what they were originally. If you tried that with 98 you wouldn't get far, hence why I am so amused when this discussion pops up each few months.
I've been running straight e85 for over 7 years now, never changed back, never touched my fuel system, never used stabilisers either. The only down side I have noticed is less K's to a tank. Any other ethanol myth is generally false. I prefer not to run the ethanol content sensor at this stage because as GTSboy mentioned they can lead you up the garden path, and it's another sensor to fail affecting the tune.
Dan, if you need it I have my old E85 205L oil drum I never use anymore, it has a servo hose and nozzle fitted. If you are interested I can send a pic. I just use 20L's these days, but I have 4 United servos selling e85 within 5 K's now.
I'm on the phone with RTA as we speak rather than working of google searches, which I've also been doing :)
I've also seen the stuff about static, you simply need to earth yourself, the drum/nozzle etc. I'm also not going to be wearing synthetic clothing or holding my phone.
For $20, happy to throw it in, not a big deal.
Would be interested to see that drum. I've got a drum but your nozzle setup sounds interesting.
Just got off the phone.
I can LEGALLY have a FULL drum IN the car. Any more than a drum and it must be trailered, placarded with dangersou goods signage and you need a license but a single drum is LEGAL
Must be secured and he advised me about the risks of ignition and fuel vapors.
Windows will be down, will drive slower than usual, will employ ratchet straps.
This information is specific to NSW, I have no idea about other states.
The issue becomes if the service station will allow me to fill it in the back of the car, given once full I would not be able to lift it by myself.
Earthing shouldn't be an issue as I can just use an earthing lead from the drum to an earthing point in the car/to the pump.
Alternatively I may need to just borrow a bunch of jerry cans from my mates and fill those instead.
Edited by ActionDan
I got pulled up for filling a plastic Jerry in the back of ute. Two chances filling up a 44 in an SUV.
Interesting, I regularly fill up 4x jerry cans and my R33 shit box and no one has ever stopped me though?
Heavy vehicles have 1000+ litres in multiple tanks, including belly tanks under trailers with no placards etc. Also a lot of Earth moving companies use portable storage tanks in Utes without problems
as a earthmover that has a big arse truck I will say this is incorrect, my truck has only one 400l tank and it does have a placard and so does the excavator which is only 110l
Also contrary to popular belief diesel in not flammable, it is a combustible liquid so the same rules may not apply
Edit: if your desiel is flammable stop buying from that servo
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
