Can u pretty please list all the mods up to stage 27 dosepipe. Thanks your a legend[emoji3]
ah shietttt
step 3.. install ebc
step 4.. increase boost
step 5.. add more boost
step 6.. might as well pull off actuator hose
step 7.. get new ecu
step 8.. enable anti lag
step 9.. add more retard
step 10.. increase length of dose pipe
step 11.. add more bends for dose pipe
step 12.. increase length of intercooler piping
step 13.. buy a massive intercooler for no reason
step 14.. convert to e85, prolong life of dose motor
step 15.. buy new turbo
step 16.. external gate setup
step 17.. I'm out of ideas
step 27.. get a 4" dose pipe
  • Like 2
I'm a little tipsy.. didn't eat lunch just drank instead.. waiting till 3pm so it's more "appropriate" take beers out of the beer fridge and drink some more.
NOt to mention I came to work hung over from a bender last night..
  • Like 1
step 28: decat
step 29: run straight thru exhaust with no mufflers for a F#ck off loud exhaust cause race car
step 30: put cap on backwards and nodd to chick's throwing wet panties...
step 31: tell fat chicks you cant let them ride, they to heavy lolj
step 32: play "riden dirty song" ,
yeah fu#ken lol.. hahahah
Edited by AngryRB
f**k me. One of them is your very own thread from 2 f**king years ago!
http://www.sau.com.au/forums/topic/445235-when-is-a-aftermarket-fuel-pressure-regulator-needed/
loooool.....come on OP, how can you expect to get serious help now, when you're asking the same shit 2 years later? It's not even a big decision, and I can't believe you've read that much conflicting information to make it that much a tougher choice. I'll help though - don't add a variable that doesn't need to be there. I had a tuner that thought it would be a good idea to wind up the base pressure so much that as soon as the rate rose under boost it would overload the fuel pump and pressure would drop, not raise, via the relief valve - even though my 550cc injectors were large enough that only a small increase in base pressure that was needed. And so I have to try and tell this experienced (and yes, he was a reputable, knowledgable and experienced tuner in all other aspects) why this doesn't seem to be a good idea. And yes after I got over the novelty of having a shiny adjustable FPR, I went to a larger 800cc injector and back to stock FPR....better in every aspect.
For one, I know a lot more about cars now then I did two years ago. So I know more of what to ask now. Also for every argument for having a FPR, I find one against. This is searching on forums from different countries, etc.
Also on this site in the RB20 Turbo upgrades with Dyno results section, there are lots of people with FPR's in their build. So no one has a definite answer.
Thanks for your take on it.
Edited by yoshiii335
There are lots of people like you who buy things without knowing why.
  • Like 1
Wrong,
There are people like me who don't buy a thing unless I know I need it and I know about.
How about you ask if I do before you assume.
Dont assume, you know the old saying with that word right?
So everyone, you know the Disney movie Frozen? Well you know the main hit song? How about all of you who keep with the smart remarks just..."Let it go, Let it go.........."
I got the info I needed early on in the thread, in fact I haven't checked this thread since last week.
Move on, I have.
Admins, please close this thread it you will.
Thank you for those who helped.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
