11 hours ago, Darmanin10 said:
Awesome setup, some top quality stuff on this build.
Whats done oil control wise though? Still standard bottomn end?
Not really much, Had a standard rebuild in Japan by Midori Seibi using an R34 block and crank etc.
11 hours ago, Robzilla32 said:
It is great seeing other people's setup and appreciating the hard work and $$$ that have gone into the build.
The gauges look great. Do you have a wider angle pic showing how they fit into the interior?
Cheers mate, Will get a better pic when i pick up the car next week. They went into a HKS glovebox insert.
  • Like 1
  • 3 months later...
Haven't been here in a while, long story short need a new motor..
Going with an RB25 AWD 23U block and will run a special Platinum brace and still keeping the T51R KAI BB kit, goal is 750 - 800hp
The whole bottom end rotating assembly will be sent to WPC Japan for metal treatment after balancing is completed.
New parts consist of...
Spool 2.8 Stroker 86.5mm CP Pistons and Full Counterweight Billet Crank
Spool Spline driven oil pump gear
All new Supertech head components, will be going shimless head..
Oversized Inconel and Nitrided valves, dual valve springs, DLC coated buckets, bronze guides etc
Ross Balancer and Cam/Crank trigger kits
Tomei 1.2mm Headgasket
Quaife ATB Front diff
Koyo 3-layer copper core radiator
Nismo engine mounts
More to come...
34146416_10156635985150572_5515712166776274944_n.thumb.jpg.065be940e39000a60b79d0becf798c61.jpg
33472196_10156621188900572_7891229892107304960_n.thumb.jpg.b216cd1b688854b11f1ac78c2c4e08dc.jpg33584486_10156620732360572_9200452712678817792_n.thumb.jpg.1889f83bdb24c6c0cf21d2e3b5a7d5a0.jpg35285174_10156674462850572_7375017235930152960_n.thumb.jpg.7212f6683776fd0dca05535f231e71d0.jpg35166897_10156674738400572_2208349888704413696_n.thumb.jpg.e5bd4f46f0ee3e1cf237541ebf4808ea.jpg
  • Like 4
  • 5 months later...
So finally been getting somewhere recently.. Received all my parts back from Japan, just waiting on piston pins to come back from getting DLC'd..
Went with ATI 1000hp Balancer instead of the Ross due to some disturbing issues I have seen.
All bottom end parts have been WPC treated.
47689404_1381961778607622_1897844450651013120_n.thumb.jpg.e4b65ae2b0d2a7cbcae880982858cc4a.jpg
48045702_842008129464227_894009172218085376_n.thumb.jpg.9e2c48956d091a300c3910e7fe2c1721.jpg
48053451_967174603479450_1063616661937979392_n.thumb.jpg.e99cf0a23f5539559c4133f1961bd1a8.jpg
48164352_533609343786220_3418861390012612608_n.thumb.jpg.f6785fba7e4b4de6cfa78ab47e5f4a43.jpg48181025_2202063330067306_2876207626671095808_n.thumb.jpg.e98fc4cf00af09a9c7d6a903e3fb1999.jpg48207444_729019384163655_5420889081406029824_n.thumb.jpg.605361f647d326c1db9922185461e007.jpg48243236_372637720154616_3332026196488617984_n.thumb.jpg.8f0db87fd21055527bd43ce7f7d000d2.jpg48266738_280070089248386_1408379600957865984_n.thumb.jpg.5a39919f27766bf699b5c790745e6db3.jpg48362184_353486265442689_7938199757535576064_n.thumb.jpg.81ca50183da8342bcf11e745e7fa85e6.jpg48369929_499627730441875_1851369348275372032_n.thumb.jpg.439400555a5106646aa4b2813747067f.jpg48373757_1515523751926040_2508967165286154240_n.thumb.jpg.2c1a489beb5fb9f373c7de9bedd4d3e7.jpg48373765_332288424022611_3459965979381989376_n.thumb.jpg.91cd14fa2741b0ddee6dc13432cecfe5.jpg48386172_299486757347349_8948986118414532608_n.thumb.jpg.33239804bc1eafcd04980c692b3d3a67.jpg
And now the block is getting line bored with this beast...
44314259_1391049111028779_8827544552320532480_n.thumb.jpg.0f201c5357532e6e2f6c3e7f2af5d18e.jpg44308743_2109073215791427_2437398660649058304_n.thumb.jpg.a27d8f14efaf53821e493223ac597839.jpg44593795_567583707029915_546314402622603264_n.thumb.jpg.ffdaf1da69ccf0897560c9ec52dec90c.jpg
  • Like 7
  • 4 weeks later...
So finally the last pieces of the puzzle have arrived..
DLC Pins and Buckets!
Block and all rotating assembly went to the machinist on monday to get all balanced and torque plate honed for the 86.5mm pistons, so that should be all done by mid next week, then we will be ready for assembly!
Few weeks to go and we might be ready for startup :D
49938748_2206177222939143_2139130787012804608_n.thumb.jpg.00aa700594cf5136a3906b46121e1958.jpg50626204_2143035439051441_5664604853133901824_n.thumb.jpg.09887da382ff1a5b42a7e0c785f8c570.jpg
  • Like 2
  • Thanks 1
  • 1 month later...
  • 2 months later...
So some tuning happened today and successful testing of the billet alloy brace from PRP, we had solid/consistent oil pressure the whole time.
Proper test will be on the track then pull down after a 6 months to see how the bearings look etc
Here's a short pull, found that one of the pumps could be on its' way out and will be looked at tomorrow then replaced etc.
  • Like 6
  • 4 weeks later...
So tuning is complete for our goal..
On pump 98 made 427kw @ 26psi..
E85 made 538kw @ 30psi but backed it off to 520kw @ 28psi
Now just want to drive it around and enjoy it and experience it on circuit!
  • Like 5
  • 1 year later...
So haven't updated this in over a year and that's because the car has been running great the whole time :D Over 6,000kms and 4 track days to date with the alloy brace still working wonders.
But in any case the GTR rabbit hole doesn't end and just gets deeper.
Next (hopefully final) phase of this project is looking like this..
  1. Alpha Omega Single piece driveshaft (Acquired)
  2. Brand new head (Had this in storage for ages) CNC ported with all new gear, shimless etc
  3. HKS V-CAM Step Pro (Acquired)
  4. Upgrade to Haltech Elite 2500 for DBW compatibility
  5. 6 Throttle ITB DBW
  6. New turbo, maybe Precision 6875 or 7175/7275??? (Don't know which one to pick yet
  7. Bigger catch can/battery in boot etc
  8. Sequential Gearbox (One day, not sure which one)
Here is some really short clips of my last session at EC in RWD just mucking around..
Edited by GRKGTR
  • Like 5
25 minutes ago, Marko R1 said:
Looks like a weapon - 3rd gear breaks out :)
It's in rwd in the video and it's tuned so the boost rolls on progressively as opposed to the cliff face type tunes lol
Only on low boost (650hp) in the vid but still fun and plenty of power
