Brembo front brakes off a Porsche 996 TT with dba slotted rotors come with adapter to fit R32 GT-R.
Swapped back to stock brakes when I sold my GTR so these have been sitting in my garage for years so will need some TLC
$1000 ONO. Can deliver free to Sunshine Coast or Brisbane if timing is right.
https://www.sau.com.au/forums/topic/464337-brembo-brake-upgrade-r32-gtr/
5928 is the GTR brembo size, 324mm, but OP can confirm. Not sure about the adapter because I can't see them in the pics, but I run the same discs and calipers on my race car and I reckon it's a bargain at this price.
Duncan is correct. 324mm
I think they are significantly under what they would usually be priced at, I just want them gone as they have sat under my house for a long time.
Good for the right person who doesn't mind installing new pads and presumably replacing the seals.
  • 3 weeks later...
Are you selling front & rear?
What is the minimum wheel size to run these brakes?
Just the front, stock rear brakes where used with this setup without issues.
A few different sets of 17" rims where used with them without issue, I don't own the car anymore so I cant comment further.
  • 2 months later...
Sorry been away for a few months - replying to PM's now.
Another member pointed out rebuild parts that should work here:  http://www.racingbrake.com/SearchResults.asp?Search=BP-406&Extensive_Search=Y
PM sent
  • 3 months later...
  • 4 weeks later...
Hey Duncan,
Were this more than enough for you? Without changing the rear and just the fronts? Braking strength good?
Im still on Stock 32's non Brembo and am looking at an upgrade - was thinking of 350mm evo Brembo's front and rear but seem overkill - just want to see your POV...
Thanks!
^ Pads easy to find? Good pads?
I'm very happy with my similar setup on the race car, I've run up to 1hr enduro races on them and targas etc with no issues. These are a bargain at the posted price even if they need a reco
  • Like 1
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
