Hmm American muscle power plant in the iconic Aussie Commo.
Not sure how that might be received..
Anyone remember the reaction of Holden fans when the VL came out with the RB30.
They were disgusted at it, but much later became very popular as everyone slowly realised the potential of the RB.
Another mongrel Holden.
Derp
  • Like 1
Interesting.
If its literally just an engine upgrade over the GTS, you'd be mad to not just get a GTS, pulley injectors and a tune surely..
In terms of taking on the europeans, the current GTS would surely have to rate higher in the fun factor (but not the luxury stakes) than the likes of the M5 or the equivalent Merc or Jag already, surely.
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
