Hi lads,
When I pulled the engine on my car last time I thought it would be a sweet idea to remove all the hard piping that zig zags across the front of the car and acts as a cooler for the P/S fluid.
My reasoning at the time was I didn't need the lines anymore as they also supplied to HICAS system which is now removed.
My question is, are those lines only there for cooling on 32 GTRs because they have a hydraulic HICAS system that produces a lot of heat? and will my P/S system have stable temperatures without them.
Also now running an R33 GTR pump.
Thanks in advance
Joey
Great! Sounds nice and cheap too.
Where are you guys mounting it, i was thinking behind the front bar on the left side
that's how I did mine :)
it's not even visible and doesn't get much airflow but with track work now zero mist or overflows where as in the past I would wet an entire rag.
Have you still got the aircond? I put mine in the LH guard.
I don't at the moment mate, but I do have all the parts and want to put it back in at some stage.
Well that's the problem at the moment.. It bloody making a mess every
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
