If Airbags Are Deployed Does This Mean The Car's A Write Off? Low Km's Accident
Was involved in a 4 car pile up last weekend.
My pride and joy which was only imported two months ago from Japan was beat up pretty bad but the accident was under 20 km's as far as I can remember as it's all blurry after the airbags went off.
1997 R33 GTST Skyline 40th Anniversary model automatic Midnight Purple, only 98,000kms on the clock.
I want to know if my car a salvageable....
Front was pushed in just touching the front of the timing case.
Engine didn't spill oil and transmission also fine.
Bonnet bent, pretty much front end damaged.
Car was towed away. .....awaiting report from insurance company to be assessed.
Csn I get it assessed? As I believe that it's repairable...
Both passenger doors open fine.
No rear damage, just bonnet and front end.
I'd post photos if I could here but haven't figured out how to yet...post-74120-0-22206400-1464557931_thumb.jpgpost-74120-0-81008400-1464557959_thumb.jpgpost-74120-0-26437200-1464558020_thumb.jpg
Edited by mercyseat
you can get it assessed but it still up to the insurance company to if they write off.
rule of thumb is if repairs are more than 75% of insured value they write it off.
from that i can see needs
lights
fog lights
bumper
bonnet
rad support
prob radiator
prob fans
all the plastics like under tray inner liners
new steering wheel
new dash
new airbags
paint
labour
i would not be holding breath for them to fix, it is a 20 year old car and OEM parts are getting hard to get
I wasn't tailgating anyone.
It's in dispute as to the car in front slammed his brakes on first hitting two cars in front of him first.
It's insured for $10000 agreed value.
I'm hoping if they write it off of possibly buying back the salvage if it's considered a repairable write off. The car's immaculate pre accident, good resale for parts possibly, who knows.
Will decide after I hear back from the assessor's in a few day's.
Just didn't know what airbags cost to replace.
I thought the definition of tailgating was too close behind to stop if the other person hits brakes..
curious who is your insurance with?
if you buy it back getting it back on the road is an expensive process as it will be deemed a write off.
you need to show receipts for all parts and work done to get it back, go through inspections, and even then most insurance companies will have nothing to do with it.
Or track it.....
And what if the person in front comes to a stop from hitting vehicle in front of them abruptly and doesn't hit the brakes?
"Tailgating is the act of driving on a road too close to the vehicle in front, such that the a distance between the two vehicles, does not guarantee that stopping to avoid collision is possible."
It would still be considered tailgating, that is the whole point. You should allow enough time to both react and stop.
I reckon it will be fixed.
Mat from nistune hit a car that pulled out from a side road, damage looked very similar. That was fixed, and he had a front mount that was smooshed also, having said that it wasn't his fault so that might come into play.
Normally...
Front Car is not at fault unless they did something malicious or downright stupid...
Middle Car is at fault for hitting Front car.
Back car is at fault for hitting Middle car.
Quite often they'll ask the Front car if they felt 1 hit or 2 hits.
If 1 hit, the collision order was Back->Middle, then Middle was pushed into Front.
If 2 hits, the collision order was Middle->Front, then Back->Middle.
Either way, Back car is normally found at fault... the only difference is if the Middle Car is also considered at fault (aka. Did they stop in time)
I'm with a reputable insurer. There's no problems there.
As to who's fault, probably more than one person's fault but me being the last car will/have copped it. Still in shock from the damage done seemingly i actually stopped less than 100 metres prior to let the car i ran into , in front out of the side street. So from stop to accident within 100 metres is fairly unfortunate. As mentioned i blacked out and only remember the airbag going off in my face.
Was just too wet, people rubber necking the car broken down on the side lane...etc etc.
For me the car's sentimental more than money is worth. My last 1994 R33 was car jacked in Sydney back in 2004. So I'd waited over 10 years to buy another one. I'd only imported this car less than two months ago....pretty bummed out about the whole shit-suation.
Regardless I've lost $$ .
I doubt I'll buy another one knowing they're a write off at 20 km's once the airbags are deployed.
Its just the reality of owning a 20yo car. Even when they are in top shape, insurance companies wont care and will write them off after small-ish accidents.
My car took a hit in the rear quarter panel, needed an arm and probably the rear quarter. Was insured for 30k and it was written off with Shannons.
I would say you are absolutely written off there.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
