Hey all
i have had my black r33 gtst for about 6 months and it gets swirl marks and scratches really easily. The car has had a respray by the previous owner.
I gave it a full detail a month ago polishing it with some autogylm resin polish then waxing with mothers carnauba paste wax. it came out very nice and i got rid of most the swirl marks and light scratches.
I wash the car weekly, it is garaged and i am extremely careful and clean when washing it.
However the swirl marks are back, it seems as though the paint is soft or something?
So i want to know, is there a paint protection, or anything i can do to the paintwork myself, that will prevent swirlmarks and make the paint last longer?
https://www.sau.com.au/forums/topic/465130-paint-protection/
Very well documented on detailing forums. Ie google.
I'll give you a quick run down.
-2 bucket wash method
-soft woolly sponge
-Soft fluffy chamois
To rid swirls
-get a RO buffer
-Some nice polishes
-Wax it
Basically it's black. They suck, you will see defects in the paint very quickly.
I reckon it would need routine maintenance every 2 months depending how anal you are with cleaning
You can apply the "consumer" version yourself, they go for around the $200 mark. The stuff advertised by pro detailers isn't generally available to the public and needs a bit more preparation and training. The benefit is the pro stuff will last about twice as long, or even more depending on car use and post application maintenance
Here is one example of a "consumer" coating - http://www.chemicalguys.com/SS6_Second_Skin_Coating_System_2_oz_p/wac_224_02.htm
Edited by junkie
Thanks for the info junkie. Im definantly going to look into this, i might just try it myself once to see how it turns out.
^ LOL
Prep is really the most important part. Even the most fancy exxy product will looks like crap and wont last if the underlying paint surface is contaminated and swirled up. And yeah, anything that sits outside 24/7 wont last long. Personally i stick to my $35 tin of Collinite 476 or Naviwax Ioncoat and reapply every 3 months or so
Edited by junkie
I've used a few different paint protection products. Proper prep and all.
They last about 2 months on an outdoor car. Maybe 5 months on a garaged car.
For $900 I want it to last 6 years.
Thats not as long as i expected, i was thinking they would last about a year. My car is mostly garaged.
Thanks for the input
  • 2 months later...
On 05/06/2016 at 5:50 PM, Sinista32 said:
Ceramic coating
Agreed.
After you've got to the Polish stage, you can go in two different directions...
A) Sealant application and then a Wax Application
or
B) Ceramic Coat and then Reload. With Plan B) you don't have to wax or re-wax
Plan A) might last 20,000Km without being in full sun. Plan B) might last 50,000Km
The way you wash and dry your car after a wash, and what products you use are important as well + a 2 bucket system.
  • Like 1
  • 2 months later...
I will never take a buffer to my car unless i have to. Slowly destroying your paint because your too lazy to spend the time to fix it properly doesn't sit well with me. Depending on what the paint is doing depends on what you need to do.
My Go-To for paint that has swirls and the odd mark here or there but is still in decent condition:
2 step wash - Sponge bath, foam lance, wash off, dry
Clay bar - Removes all the dirt in the swirls which is why you can see them. All cars will get the swirls. Needlessly taking a buffer to it is lazy, and it is bad for the paint.
Zaino Z-CS seal - Use DIRECTLY after the clay bar. Let it sit for a day or so.
*Insert choice of wax here*  - The next day i will usually use another form of wax over the top. Depending on what the car is doing will depend on what wax i use. For example:
Meguiars Nxt Gen 2.0 Wax adds the most incredible depth to the paint, but it doesn't last as long as others. So i would use it before a photo shoot or a show n shine etc.
because i actually enjoy washing and cleaning my car the GTR usually doesn't get anything other than Nxt gen wax tbh, but that's because i'm happy to wax it 1 time a month or so. Not that it matters, the Zaino stuff lasts MONTHS. I use the Zaino on the cube as well. No wax on top, one of the guys at work commented that my paint looked better than the 2014 audi parked next to me. Cube was made in 05 with stock paint.....
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
