Hey all
i have had my black r33 gtst for about 6 months and it gets swirl marks and scratches really easily. The car has had a respray by the previous owner.
I gave it a full detail a month ago polishing it with some autogylm resin polish then waxing with mothers carnauba paste wax. it came out very nice and i got rid of most the swirl marks and light scratches.
I wash the car weekly, it is garaged and i am extremely careful and clean when washing it.
However the swirl marks are back, it seems as though the paint is soft or something?
So i want to know, is there a paint protection, or anything i can do to the paintwork myself, that will prevent swirlmarks and make the paint last longer?
https://www.sau.com.au/forums/topic/465130-paint-protection/
Very well documented on detailing forums. Ie google.
I'll give you a quick run down.
-2 bucket wash method
-soft woolly sponge
-Soft fluffy chamois
To rid swirls
-get a RO buffer
-Some nice polishes
-Wax it
Basically it's black. They suck, you will see defects in the paint very quickly.
I reckon it would need routine maintenance every 2 months depending how anal you are with cleaning
You can apply the "consumer" version yourself, they go for around the $200 mark. The stuff advertised by pro detailers isn't generally available to the public and needs a bit more preparation and training. The benefit is the pro stuff will last about twice as long, or even more depending on car use and post application maintenance
Here is one example of a "consumer" coating - http://www.chemicalguys.com/SS6_Second_Skin_Coating_System_2_oz_p/wac_224_02.htm
Edited by junkie
Thanks for the info junkie. Im definantly going to look into this, i might just try it myself once to see how it turns out.
^ LOL
Prep is really the most important part. Even the most fancy exxy product will looks like crap and wont last if the underlying paint surface is contaminated and swirled up. And yeah, anything that sits outside 24/7 wont last long. Personally i stick to my $35 tin of Collinite 476 or Naviwax Ioncoat and reapply every 3 months or so
Edited by junkie
I've used a few different paint protection products. Proper prep and all.
They last about 2 months on an outdoor car. Maybe 5 months on a garaged car.
For $900 I want it to last 6 years.
Thats not as long as i expected, i was thinking they would last about a year. My car is mostly garaged.
Thanks for the input
  • 2 months later...
On 05/06/2016 at 5:50 PM, Sinista32 said:
Ceramic coating
Agreed.
After you've got to the Polish stage, you can go in two different directions...
A) Sealant application and then a Wax Application
or
B) Ceramic Coat and then Reload. With Plan B) you don't have to wax or re-wax
Plan A) might last 20,000Km without being in full sun. Plan B) might last 50,000Km
The way you wash and dry your car after a wash, and what products you use are important as well + a 2 bucket system.
  • Like 1
  • 2 months later...
I will never take a buffer to my car unless i have to. Slowly destroying your paint because your too lazy to spend the time to fix it properly doesn't sit well with me. Depending on what the paint is doing depends on what you need to do.
My Go-To for paint that has swirls and the odd mark here or there but is still in decent condition:
2 step wash - Sponge bath, foam lance, wash off, dry
Clay bar - Removes all the dirt in the swirls which is why you can see them. All cars will get the swirls. Needlessly taking a buffer to it is lazy, and it is bad for the paint.
Zaino Z-CS seal - Use DIRECTLY after the clay bar. Let it sit for a day or so.
*Insert choice of wax here*  - The next day i will usually use another form of wax over the top. Depending on what the car is doing will depend on what wax i use. For example:
Meguiars Nxt Gen 2.0 Wax adds the most incredible depth to the paint, but it doesn't last as long as others. So i would use it before a photo shoot or a show n shine etc.
because i actually enjoy washing and cleaning my car the GTR usually doesn't get anything other than Nxt gen wax tbh, but that's because i'm happy to wax it 1 time a month or so. Not that it matters, the Zaino stuff lasts MONTHS. I use the Zaino on the cube as well. No wax on top, one of the guys at work commented that my paint looked better than the 2014 audi parked next to me. Cube was made in 05 with stock paint.....
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
