this Zaino kit pretty much sums up how I feel about high-end car care. every product requires a different type of cloth to rub off.
Contents are:
Z7 Wash Shampoo
Z18 Clay
Z6 Ultra Clean Gloss Enhancer
Z-AIO Paint Cleanser Polish
Z2Pro Sealant
ZFX Curing Agent
Z8 Grand Finale Spray
Z9 Leather Cleaner
Z10 Leather Conditioner
Aquatouch Wash Mitt
Aquatouch Ultra Drying Cloth
Aquatouch Super Soft Gold towel to buff off clay lube residue
Aquatouch Edgeless Polish towel to buff off Z-AIO residue
Aquatouch Super Soft Purple towel to buff off Z2pro residue
Aquatouch Ultra Soft Grey Towel x 2, one for Z6 and one for Z8 buffing
Aquatouch Microfibre Applicators x 2 to apply Z-AIO
Foam Applicator to apply Z2Pro
Aquatouch Microfibre Applicators x 2, one for Z9, one for Z10
Aquatouch GP Blue towel to remove Z9 residue
Aquatouch GP Green towel to even out Z10 application if require
Don't need to use all of their products. I only use the Z-CS. Apart from that everything else is meguiars.
I used a massive pack of microfibre towels from costco that i literally throw out after 1 use for most of my cleaning. Zaino is the only exception. But i put the pads in a zip lock bag and use for a few uses and then throw out.
for the steps i stated:
1 or maybe 2 fibre cloths to buff the wax
1 application pad for the zaino wax
1 chamois
2 sponges, 1 for body and 1 for wheels
1 MF cloth to help remove the clay bar residue if need be.
That bag of MF cloths is like $15 from Costco and it lasts me a year....
Don't fall for all of the advertising. Now don't get me wrong i have like over $1000 worth of cleaning products. Including detailing brushes and all sorts of things. But you can literally go:
Bag of MF cloths: $20 odd
Sponge: $13
Wax: $60
Clay kit: $35
Car wash: $25
Zaino Z-CS: $60
Applicator pad: $10
So total: $223 and that will last you farken ages.
  • Like 2
And if you really want to get into it you can get more. But that stuff will make the outside looks a million bucks. The only thing i would recommend on top of that is Meguiars Trim detailer and Scratch x 2.0 if you have little scratches.
You see swirl marks because you have damaged the clear coat in some way. Using a clay bar does not remove swirls.
Your paint will fade before you buff all the clear off of it.
Also nxt gen wax is an abrasive wax. So yes you are slowly destroying your paint aswell.
  • Like 1
Costco towels tend to lose their softness and leave a lot of lint after being washed a couple of times. Good for general purpose use but I use better quality towels for wax removal. My Meguairs cloths that are still going strong, probably around 10 years old now
  • Like 1
Some good advice in this thread.
Wheres the best place to get this zaino Z-CS from?
And yeah the microfibres from costco are a bargain.
You can get it from waxit for about $60 delivered.
I clayed the car and used the zaino Z-CS followed by carnauba wax the day after. The car came out pretty nicely, has a few swirl marks though which i didnt bother trying to buff. The zaino is easy to apply and i only used about 10 sprays for the whole car.d9cdd9d89d3a644e9173b51426733781.jpg
Not the best pic, should have taken one with better lighting
  • 3 years later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
