Car makes a bit over 330rwkw on 22psi on e85 - R34 with 86ks and healthy comp.
Has all the usual supporting mods, big exhaust, cam gears, twin turbo pipe mod, Haltech etc.
Was considering bumping boost to 25-26psi or so for a little bit more punch, but don't know enough about how to read comp graphs to tell if there's any point. My reading of this implies that more boost won't actually equate to much additional air flow? Is that correct?
Have also heard about heads being lifted at this boost, is there any truth to that and what are the symptoms? coolant in the cylinders/oil or vice versa? I can put ARP studs in if necessary. For what it's worth, car runs very cool with oil cooler and vented bonnet and guards, oil and water temps are always very stable. I haven't seen above 85 or so deg water/oil temp and 650 deg EGT with spirited driving through the hills. Intake temps are good also.
Was also contemplating switching to those 65mm K&N pods that bolt directly onto the AFMs and running an enclosure, possibly modded to allow me to retain snorkel. This is purely a rice mod for the noise and fun factor, but is there likely to be any power loss in the real world? I do have the vspec intake temp readout on the MFD.
Edited by ActionDan
boost doesn't lift heads, cylinder pressure does and 350kw seems to be that magic number as you've been informed a number of times
As for upping the boost to see more power, reading a compressor map isn't going to tell you anything. Just crank it and see what it does
Changing to pods isn't going to do anything but it's your money do as you will with it
I should've specified, not boost specifically, cylinder pressure.
No I have not been informed numerous times that 350 was the magical number for that, nor could I find it when searching. SAU search sucks copious cock.
I'm not looking at pods for power, just the fun factor when driving it (noise). That question was more related to any negatives I might encounter, if I can deal with heat management well enough. Something like, I ran K&Ns at that power and they collapsed, etc.
Has anyone spun up there -9s to 25-26?, again, if I could find that easily, I wouldn't ask.
Throwing on the dyno means dropping the front shaft, getting it there for a touch up tune, then seeing what happens. It costs me less in time and effort to at least see if anyone else has done it. I may find that they just shit the bed and pump bulk heat after 23-24psi, I don't know, I've never run these turbos and don't know what if any relevance the comp map has to my question.
Hence seeking the experience of others.
Edited by ActionDan
I think you might be misreading the maps you posted. The left map is the compressor map, the right map is the turbine map. The turbine map flattens off at the sort of pressure ratios that you're talking about (2.5 and up) but those pressure ratios you're talking about are boost, not the PR over the turbine. So totally irrelevant.
Unfortunately, to read the comp map and say whether adding some more boost will result in any benefit we have to know exactly where you fall on the map now, which is not really clear. Your PR is clear enough, it's pretty much 2.5. What that means is you must be somewhere on the map to the right of the 17lb/min line on the air flow axis, otherwise you'd be surging. But the problem is knowing exactly how much air you are using to make your power.
Horrible simple maths says 330 / 0.75 / 0.75 = 586 HP. At about 10 lb/min needed per HP and divided by 2 for 2 turbos, you are in the ballpark of 29 lb/min air flow.
On the 2.5 PR line, that is right over on the right hand side of the map. Going up in PR from there takes you off the map and up to massive shaft speeds too. Even if you are not that far over to the edge of the map, say at 26-27 lb/min, then going up to 26-27 psi will take you right up to the top edge of the map.
You have been told about the 350 causewe said it in your build thread countless times before you got your car tuned.
If I can push -7s to 24psi without any issue then your -9s will be fine as well
ARP studs are cheap
Changing studs (without removing the head OR cams) is also a cheap/easy process...
Just change studs and add in as much boost as possible, i.e. still no more power can be made :)
#e85lifey0
Really useful, thanks. So from that I can infer that it will "work" but with a notable increase in required shaft speed to maintain the pressure ratio for a given airflow requirement - if the engine is actually ingesting that many lbs of air per min. So, test it and see... What sort of behavior would I be looking for to know it's unhappy? I imagine I'll have more resistance to surge due to the twin turbo pipe mod, or do you mean surge differently?
Again, only relying on SAU search, but I can't see that mentioned, I tried searching for 350, head lift, head gasket etc. Happy to be proven wrong, but ultimately, even if I was told, I didn't remember, and asking the question in a more visible location isn't going to hurt anyway.
What did you make again on 24?
Edited by ActionDan
And the money you're planing on wasting for pods I'd be putting toward a crank trigger system. They allow you to push the timing so much closer due to not having any fluctuations in the map there fore more power :devil:
Suck it and see has a strong element of truth because of the unknowns making it impossible to be too scientific.
More specifically answering your above questions though.....The compressor map pretty much shows where you can use the compressor. If you run off the right hand side, you are generally spinning it too fast and bad things will happen. You start to eat into the mechanical limitations on how strong the wheel itself is, and of course the efficiency drops as you go to the right of the island. You're already only at 65% at the right hand edge. Going further to the right does as you originally asked - it makes hot air.
Keep in mind one thing. Unless you do start to make hot air and actually go backwards, the intention of adding boost is to add air flow. Let's play an imaginary game. Place your operating point on the intersection of the 2.5 PR line and the 25 lb/min line. If you wind the boost up from 22 to 26 psi then your PR goes up to 2.7. But you don't go up vertically, because if you did so you would only be running more boost, not flowing more air. So you have to go up at some angle to the right. If you started at the operating point I described, then at PR 2.7 you might well end up very close to the right hand edge of the map. You also would have fallen off the efficiency island (>76%) and would probably be down in the 72% efficiency region. You'd definitely lose some potential power from that.
It gets worse. On top of all this compressor side stuff, the turbine has to be able to provide the extra power to drive the compressor. It probably can, there's probably well and truly enough power available, but on some turbos you might just end up choking the back end. This all depends so much on the total package or turbo and engine that it is even harder to say without some direct measurement (suck it and see on the dyno basically).
And how many millions of GT-R taxed dollars is that lol
Understood, and thanks again. So realistically with the current gear I have, all I can monitor is intake temp, maybe EGT, and that's it? given I don't have a way of measuring turbo shaft speed.
  On 09/06/2016 at 5:06 AM, Hadouken said:
Yes there was one person then he sold his car because he ran a slow trap speed but was making "380" kW on -9's
Sorry what was that in reply to?
There are a few versions around, there was for sale on here and would have been all done for under $700, the one I got was 1,000 but requires an aftermarket balancer and there the Ross one that's 2.5k plus
Yup, monitor those things, see if it will make more power.
Measuring exhaust manifold and dump pressures may be educational too, but that is going to quite a lot of effort. A better estimate of flywheel HP would provide some more confidence on where exactly on the compressor map you're sitting. My maths was using a big, rough 25% dyno factor. A few % either way can change things.
OK Cheers.
Understood. and thanks for the detailed info.
Hopefully dumps should be up to task, they are the 3" HPIs into 3.5" front pipe and 3.5" all the way from there.
Has anyone else pushed -9s to this level or does everyone stop at 22 because that's where they stop making wasps.
Mate you own a 34, buy a set of head studs and get it back on the dyno. Removing the front shaft isn't that hard and cost of the extra dyno time will be worth it. It's really stuff all cost compared to what you payed for the car and what a rebuild is worth....
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
