"So im trying to squeeze a 19x11 +20 295 30 out back. Camber is -2.2 should Iget a narrower tyre or drop camber to -3.2 would that work? "
Answer - you are prob better off going orig camber spec with a 275 tyre
The Michelin PS4S tyres run wide, so heads up there. In my rear, I was replacing a 305 Hankook V12 with a 305 Michelin PS4S, and now I rub a tiny bit. I have my bumper bracket trimmed, but apparently not enough. I can also increase my rear camber a little bit to pull the tops in, I'm currently at -1.2 in the rears, so I could go -1.5 to -1.7 or so and still be fine. Or I can just trim the bumper bracket a little more.
Fronts are 275/35/19 on a 19x9.5 +45 and the rears are 305/30/19 on a 19x10.5 +43, Rays Wheels are Rays Gramlights 57Xtreme, tyres are Michelin PS4S, Lowered on Swift springs
  • 1 month later...
2008 Nissan (V36) Skyline 370GT Type S Coupe..
Wheels: TSW Bathurst..  Tyres: Continental Extreme Contact DWS06..
Suspension: Stock..  Modifications: None..  Rubbing: None..
 Front: 20x9 +30  (245/40/20)..   Back: 20x10 +40  (265/35/20)..  could fit 275/35..
5931795726640_V36NewWheels.thumb.jpg.4d929e6aba20248c0de5f258427798b2.jpg5931798b1d243_V36NewWheels(1).thumb.jpg.68926688fee08aecfbbec2b76ac6bfc1.jpg
Edited by taranaki gloria
  • Like 2
  • 4 years later...
D-Speed DS02
Front:  19x9.5 +25 Falken FK510 245/40 19
Rear: 19X10.5 +22 Falken FK510 265/35 19
Front fitment is great, no issues
Rear offset not ideal, running -3 camber and had to cut up bumper bracket.
Edited by mooij
  • 1 year later...
Joining in the fun from Singapore.
Car lowered with Tein Flex Z, running on a set of original Ferrari California wheels with customized spacer with long bolts of 30mm protrusion to fit the thick hub of the Ferrari wheels.
Front:
8Jx20 +44. Customize 25mm spacer with inner CB 66.1mm outer CB 67.1mm. Running on 245/35R20 rubber.
Rear:
10Jx20 +52. Customize 20mm spacer with inner CB 66.1mm outer CB 67.1mm. Running on 275/30R20 rubber.
No rubbing. Stock alignment setting and fender not rolled.
  • Like 1
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
