R32 gtst over heat
Hi all!
Ive got a r32 gtst. I was driving on the free way and flawed it abit. My temp gauge it 'H' so I stopped. Had a look no leaks or anytbing. Cruised it home and was fine. Had a look at the oil and wasn't milky either. I've bought a radiator off a r32 gtr. Flushed it and re filled it with coolant. I let the car idle for 1 hr as I let the bubbles out. The temp didn't move  at all from cold. I then took it for a drive and it rose just sbit over 'C'. Is this normal
https://www.sau.com.au/forums/topic/466743-r32-gtst-over-heat/
R_34, I have done a full service including the change of the thermostat water pump and coolant before it over heated.
The water in my old radiator was pretty brown and dirty. Could that have also been a issue?
Being an Iron block, the coolant need to be changed more regularly to avoid rust of the coolant galleries in the block.
The rust particles that get in the coolant tends to block the thermostat. Your symptoms (car not heating stationary and barely heating when driven) leads to a thermostat stuck open or partially open that allow too much coolant to be cooled in the radiator.
When the car overheated on the freeway the symptoms leads to a stuck closed or partially open thermostat allowing too little coolant going in the radiator.
And you say that you changed the thermostat before the overheating so I repeat : your thermostat doesn't seems to work correctly. Was it an oem unit ?
Edited by R_34
  • Like 1
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
