Engine Carbon Clean?
Hi,
My daily ride is a Subaru.  Dealership and the local mechanic do the good 'ol "tune up in a can" and spray the upper cylinder cleaner in then out the exhaust is a black haze of built up carbon deposits.  I'm wary of miracle cans (besides WD40) but enter Engine Carbon Clean.  Doing some digging, they started in the UK and have spread their wings to VIC.  Can't find a bad review, but can find before/after on same day dyno runs and the results look good.
I'm thinking about rolling the dice and giving it a crack on the GTR.  Thought I'd throw it out there, anyone done this or similar before?
Cheers!
https://www.sau.com.au/forums/topic/467478-engine-carbon-clean/
Always a bit wary of these products:
1.  Why is your engine so gunked up it needs this stuff, better addressing the issue?
2. If its a new rebuild and its done right then you shouldn't need it anyway.
3. If its an older motor and you use it the chances are you will remove the carbon that the motor has come to rely - the results could be worse performance/reliability.
4. What end result do you hope to get out of doing it?  is it worth it?
5. How often do you intend doing it?  Every 5K, 10K etc?
Maybe if you purchased a low mileage car driven by granma to bingo [where the oil never ever got warm], and it needed a fresh start in life, but otherwise I can't see the benefit.
when i had the head off recently replacing head gasket, i used the liqi-moly carbon cleaner to get rid of the carbon buildup on top of the pistons (rb25det). It worked well, in that it really dissolved it, but even then some small spots took heaps, letting it sit, and then some scrubbing to get them removed completely. Pistons looked great afterwards though. So not sure how much carbon these products would remove if just sprayed into the intake, doesn't seem they would remove the really caked on stuff...and don't know how long it would take before it builds up again?
.... So not sure how much carbon these products would remove if just sprayed into the intake, doesn't seem they would remove the really caked on stuff...and don't know how long it would take before it builds up again?
The Subaru can spray is part of a regular service. Spray and idle I believe. AFAIK the Engine Carbon Clean mob take 30+ minutes to finish up the job. I'm waiting for a call back and I'm going to ask a stack of questions.
Keep in mind all those euros and the VQ carbon build up thread are all for direct injection motors. They get heaps of build-up in the intake side, unlike regular fuel injected motors. So their power "gains" are going to be much more significant than yours.
  • Like 1
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
