Buying a r33 gtst
Hi all,
So recently I drove my mates r33 (first rear wheel car I've ever driven) and that was enough to make me buy one.
I've got about a 25k budget and I want to space out the mods for the car so I don't kill myself.
Just want answer pls
  • What mods should I start with
  • What is the most psi I can run
  • any suggested mechanics (North Perth)
And anymore things for a newbie to know.
Thanks
https://www.sau.com.au/forums/topic/467576-buying-a-r33-gtst/
Read the R3B25 and RB30 turbo upgrade threads to see what people do and with what results and work out where you want to get to. Nothing more money wasting than doing things twice. With your budget i would take the time to look for a nicely modified car and save some time and money.
My opinion this is what i did with mine first and its what i recommend.
1. Complete service - new oils (engine, gearbox, diff) new filters (oil, air, fuel) new plugs, check belts. this way you know exactly what you have in your car and that it all has been done.
2. Brakes - upgrade to new pads and rotors, don't skimp here get yourself something decent
3. Tyres - check to see what is on the car currently, if it is a cheap unknown brand, get something that is known and quality.
4. Suspension - Coil overs or decent strut/shocks and springs, check all your bushes, upgrade sway bars.
now you have a good solid platform that will handle when needed and will stop, you can start looking at power.
5. Elec boost controller and new BOV, the stock turbo will handle up to 12psi, with a GFB boost controller you can adjust alot of perimeters like spool up rate, max boost, overboost cut etc. reason for new BOV is over time factory ones can bleed boost. Don't buy ebay stuff, do it once do it properly.
6. 3" turbo back mandrel bent exhaust.
now you have enough power to have fun with for a while till you get comfortable with the car. From here the mods are relative to the depths of your pockets
New turbo, coil packs, fuel system upfrade, ECU, Tune, E85 etc etc
From the questions you've asked I can already tell that you are pretty excited about making the purchase.
Basically have a good think about @Coullsy's post. Rather than focus on "the most psi" focus on the handling side of things such as brakes, tyres and suspension first.
There's really no point having huge power with no back up to stop you when it's needed most.
  • Like 1
its been mentioned before but i agree spend the money of making the car handle and stop before you look at power (dont cheap out on tires and wheels).  first power mods i made to my r33 were bigger injectors i put an r34 turbo in with 3in turbo back exhaust front mount z32air flow meter and new computer with nistune, with the r34 turbo im running 17psi.
im now looking at either building a forged rb26dett or doing an ls1 conversion because im used to the power now.
21 hours ago, conan7772 said:
Hi,
I'm thinking of selling my GTS-T 95
Already a rocketship.
Forged 25/30 337 rwkw
Got all the goodies.
I'm after $22000.
I will be putting up all the info soon,
I'm in Sydney though.
Create a for sale thread.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
