Dude, as I said those circuit slicks aren't going to do the job you want!
BFG DRs or drag slicks will however, and it's well documented what size DRs and what size drag slicks work on a GTR.
Remember the BFG gForce DRs in 17"/18" aren't what you want. You want the 15" BFG Comp TAs with nice big fat sidewalls (50/60/65 profile).
im gettting a set of 16in standard gtr wheels from bu5ter on the weekend, hopefully ill be able to get some 245 or 255 width, and 50 or 60 sidewalls. depending on what sizes bf goodrich make.
  • Replies 163
Guest two.06l
i have to go pic up the cage during the week, its mild steel so hopfully will be sufficiant.
the only problem is there is never enough hours in the day to get things done
who is supplying the cage and are they following the andra technical direction in its construction if so can we be given their details so we can get one too.cheers paul
correct x2. Make sure the cage is legal. ATM most of the cage makers are super busy and expensive with ppl building cars for WSID.
The guy I used is in the same complex as UAS about 4 shops back, cheapest approved cage I could find. Thats CAMS not ANDRA of course but he was doing ANDRA cars too I think.
You do not have to use Chrome Moly for your cage, but if you do then it must be tech inspected by ANDRA before painting. if you use mild steel the size required is larger than the CM equivalent.
It is true that most shops are flat out busy at the moment.
flaunting rulz is run, if they dont accept the cage then why should i spend another 2gs on a cage and more fuel just to race, changing the plates costs me hardly anything, i might not run another 10 ever again, so im not sure if its worth it.
Mate, I think you need to take the safety rules a fair bit more seriously. Not that running a non-ANDRA approved cage will cause you to crash but more that an attitude that ignores these saftey regs could.
And Doughboy, "...and you plow into a wall." isn't really an image any of us want. You made your point but I don't think that's the best way to do it.
Adrian
Oh sorry, I should have worded it "sneaks up and kisses the wall delicately". It's sad but only a graphic image is going to make people think about what could happen, especially in high speed motorsport. What about catapulting the car if the tailshaft snapped near the gearbox, or the transfer case/diff(s) locking up and make the car slide into the competitors lane and push that into a wall, or a flywheel exploding and loosing your feet etc. etc.
The rules are there for a reason, not to generate income in a cottage industry or to slow people down. Sometime you have to wonder what the consequences could be....
i already know what the consequences are, ive been around racing a long time, ive seen what can happen, i know rules and regs are there for peoples safety, but after i get a lower 10 i think ill give racing a miss for a while.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
