Ken's z31 I wanna go fast build
I am Ken from the Seattle area USA. I bought my 1985 300zx GLL non turbo 5 speed in 2011 with the impression it had blown head gaskets which only an RB  swap would remedy. I replaced the bad thermostat and drove it for 4 years.
Opportunities arose and I purchased a wrecked 87 300zx with what I assumed was a stock rb20 silver top and 5 speed swap for $800 usd. Car had been sitting for 6 years after the owner wrecked.
  • Like 1
https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/
Engine was siezed so I started to take it apart. What I found blew me away.
Internal:
.015" over custom Wiesco pistons
spool rods
full balanced rotating assembly oil snout to pressure plate
spec stage 3 6 puck sprung clutch and flywheel
acl bearings
hks step 1 cams 264/264
adjustable cam  gears and greddy timing belt
bolt on:
rc racing 750cc injectors
precission 5557e dual ball bearing with billet wheel
z32 maf
aeromotive fpr
Nistune type 2 board
The list of parts well exceeded my $800 paid for the siezed block.
I discovered the heard was ported by a hydroplane mechanic.
I have no idea as to what power the car made or what psi the tune was done at. All the info I have is the car ran for two weeks and then it was totaled.
Welded in a nipple for the iacc and Aacv as well as a flange for the synapse engineering synchronic bov.
Also a 3 core s13 radiator modded to fit and a custom made shroud for the 14" fan. Unsure on cfm but the shop who built the car for the previous owner had used an oem vgz31 radiator and shroud with this fan tucked inside very crudely. Lower coolant hose is fitted with a temp switch for the fan relay.
  • Like 1
Also when the previous owner of my 85 had taken the car in for diagnostic the brilliant mechanic decided to dump head gasket stop leak into the system and I did not want to chance the  heater core to fail and fill my fresh rb and radiator with stop leak.
My Z has modded knuckles, running s13 Lcas and tie rods with the rack moved forward 25mm to prevent over centering. Of course I have no pictures of my own parts. S13 coil overs front and rear and s14 tension rods. Welded diff and poly bushings but one day will have s13 subframe.
I will attempt to snag some photos in the day light.
Edited by Zrbsliding
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
