SKYLINE WONT START ! HELP !!
So hear me out first guys, hear the full story it might help !!
i changed my Blitz Pod filter to a K&N one
Car was running fine, and on my way back home I decided to give it abit in the tunnels, after giving it all the sudden my car started choking or chugging and I thought my engine died, but it was still running, it runs fine till I step on the pedal half way it chugs and struggles and pretty much wont let me Go over 3,000 RPM so I thought maybe it's the POD that's acting up the AFM cause it felt like it was the case.
So the next day I changed it back to the Blitz that I originally had earlier on and went to drive it around and it was back to normal "woooooooo" and as I got close to home it did it again the chugging and choking like it was gonna die, so I was f.. could it be my spark plug or coils.
So the next day I changed my Spark Plug, it was a BKR5EIX-11 which isn't recommended but I had it laying around so I replaced it, my old spark plug was black and burnt on the tip so I thought yeah maybe this should do the trick!
Plug everything back in and....
it CRANKS AND STARTS FOR A SPLIT SECOND AND immediately dies out and I only have one conclusion left, the Coilpacks but I want to see what you guys think
-every hose is plugged in correctly and tightly
-strange thing is that before I change the spark plug the car was running but a weak start up so I thought Spark plug but now I don't even know anymore.
PLEASE HELP ME GUYS !! Could it be the coilpacks ?? Could the spark plug have anything to do with it, even if it's not recommended it should still start up, it's gapped at 1.1 which is how the plugs came (Bkr5eix-11)
https://www.sau.com.au/forums/topic/467861-skyline-wont-start-help/
I replaced it with bkr5eix11 cause I had it sitting in my rooms for years for my NA/R34 which was recommended. And nah doesn't seem like a fuel issue, I got half a tank and I can definitely hear the fuel pump just before starting the car
From what we can tell the only thing changed was the filter, I would look at the Maf extensively to check for damage.
My car would not start and sputtered going into boost when the plugs were fouled. Also check for ground wire to coil packs/ignitor.
Have you considered that it could coincidentally be an alternator or battery that is no good? It's a big leap, but you should probably just check how many volts you have on the battery terminals before and during cranking.
33 minutes ago, Jonic said:
The ecu is stock and fuel line is good, I think it's the AFM since I change the Pod around and maybe it bounce around too much and played up perhaps
Well just unplug it and see if it starts.
LOL so I tried starting her up after work and guess what, it started weak and actually stayed on, Tried it again 10mins later and wallah it's starting up and running all good again ! Haha what a confusing moment, what in the world happen ??
Now everything it out back together the car runs but the PROBLEM OF THE LIMP MODE IS STILL THERE !! I can't even rev pass 2000rpm, even when parked! Something must be playing up and I'm thinking it's the AIR FLOW METER. Ever since I changed the Pod Filter the problem started, but the thing is I changed it back to normal but it's still limping, I can't even hit 60Kms on the road :0
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
