SKYLINE WONT START ! HELP !!
So hear me out first guys, hear the full story it might help !!
i changed my Blitz Pod filter to a K&N one
Car was running fine, and on my way back home I decided to give it abit in the tunnels, after giving it all the sudden my car started choking or chugging and I thought my engine died, but it was still running, it runs fine till I step on the pedal half way it chugs and struggles and pretty much wont let me Go over 3,000 RPM so I thought maybe it's the POD that's acting up the AFM cause it felt like it was the case.
So the next day I changed it back to the Blitz that I originally had earlier on and went to drive it around and it was back to normal "woooooooo" and as I got close to home it did it again the chugging and choking like it was gonna die, so I was f.. could it be my spark plug or coils.
So the next day I changed my Spark Plug, it was a BKR5EIX-11 which isn't recommended but I had it laying around so I replaced it, my old spark plug was black and burnt on the tip so I thought yeah maybe this should do the trick!
Plug everything back in and....
it CRANKS AND STARTS FOR A SPLIT SECOND AND immediately dies out and I only have one conclusion left, the Coilpacks but I want to see what you guys think
-every hose is plugged in correctly and tightly
-strange thing is that before I change the spark plug the car was running but a weak start up so I thought Spark plug but now I don't even know anymore.
PLEASE HELP ME GUYS !! Could it be the coilpacks ?? Could the spark plug have anything to do with it, even if it's not recommended it should still start up, it's gapped at 1.1 which is how the plugs came (Bkr5eix-11)
https://www.sau.com.au/forums/topic/467861-skyline-wont-start-help/
I replaced it with bkr5eix11 cause I had it sitting in my rooms for years for my NA/R34 which was recommended. And nah doesn't seem like a fuel issue, I got half a tank and I can definitely hear the fuel pump just before starting the car
From what we can tell the only thing changed was the filter, I would look at the Maf extensively to check for damage.
My car would not start and sputtered going into boost when the plugs were fouled. Also check for ground wire to coil packs/ignitor.
Have you considered that it could coincidentally be an alternator or battery that is no good? It's a big leap, but you should probably just check how many volts you have on the battery terminals before and during cranking.
33 minutes ago, Jonic said:
The ecu is stock and fuel line is good, I think it's the AFM since I change the Pod around and maybe it bounce around too much and played up perhaps
Well just unplug it and see if it starts.
LOL so I tried starting her up after work and guess what, it started weak and actually stayed on, Tried it again 10mins later and wallah it's starting up and running all good again ! Haha what a confusing moment, what in the world happen ??
Now everything it out back together the car runs but the PROBLEM OF THE LIMP MODE IS STILL THERE !! I can't even rev pass 2000rpm, even when parked! Something must be playing up and I'm thinking it's the AIR FLOW METER. Ever since I changed the Pod Filter the problem started, but the thing is I changed it back to normal but it's still limping, I can't even hit 60Kms on the road :0
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
