fuuark that, big cams are gay on a stock motor.. I would go big cams if I had a built motor, solid lifters, cnc ported head, blah blah blah and rev it's mum to 10k rpm witha  sequential box.
But nah.. it's a stocker heap of shit.
Goal: 400kW stock bottom end.
  • Like 2
mateeeeeeeee I love bunnings :)
Will be making a front splitter from marine ply.. will be solid, flexible enough and won't produce any "flutters" which can occur with shitty aluminium stance splitters. When there's enough air movement and it starts to flutter the entire splitter would rip off. Good explanation:
Flutter is a dynamic instability of an elastic structure in a fluid flow, caused by positive feedback between the body's deflection and the force exerted by the fluid flow. In a linear system, 'flutter point' is the point at which the structure is undergoing simple harmonic motion - zero net damping - and so any further decrease in net damping will result in a self-oscillation and eventual failure. 'Net damping' can be understood as the sum of the structure's natural positive damping, and the negative damping of the aerodynamic force. Flutter can be classified into two types: hard flutter, in which the net damping decreases very suddenly, very close to the flutter point; and soft flutter, in which the net damping decreases gradually
shhuuuuuuuuu baby, from what I gather the G3SAT will dose like a bawse  (from watching Jason Ferren's R31 Drift Wagon).
Brah plenty of brake fluid left ulleh, when ize put new pads in dat brake fluid will be le tits.
(brake fluid low because of worn brake pads and air in the ABS system from when I did the Brembo brakes up front, was full till I kicked off the ABS a few times then bleed some fluid and never bothered to refill it)
  • Like 1
7 minutes ago, admS15 said:
Maybe time for bw ts 8374? Will then be the ultimate le siet bok. Ultimate efames as well ulehemoji3.png
This guy... I agree with this guy!
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
