Dug up some old data prior to the motor blowing up. Managed to crack the 200km/h barrier down the main straight of Wakefield Park - this back up the car was making some decent power till it spat ring lands (we all knew it was going to happen).
Machinist should be back soon from his last minute holiday and I'll get the crank back then it's party time (maybe).
I have a track day I'm running with Yez Racing guys so would be nice to have the car running. Let's see!
  • Like 1
  • 1 month later...
3x months later I've gotten my crank back, what an adventure with that shop. Not to mention they decided to charge me more as well, what arseholes.
Anyhow that aside, I've gotten my cam covers powder coated black because stealth is best.
  • Like 3
  • 3 weeks later...
18 minutes ago, GTofuS-T said:
Size?
Are they much lighter?
Went yalla habibi spec, 18x9.5 +22. Has some homosex 245 wide tyres, once the car is running again OR when I decide to put a motor and gearbox into it I will get the guards cut/reshaped to allow 265 semis to fit under the guards and look stock. No gay stretch no gay camber.
And funny enough, the Rays 57S aka Gram Lights are indeed lighter than the OEM GT-R wheels.
15 minutes ago, admS15 said:
Much betterer
Thank you sir, need to make the car look good before it runs lol
  • Like 1
Pull your finger out and get cracking son. FYI, i have 18 x 9 +22 all round with 265/35. Fit good. Rear guards are rolled a bit, running -2 camber and front has unrolled +20mm fenders. With 265 on 9 inch there is about 5-7mm clearance to the upright.
Decided the block should be painted black, so it got painted black.
Also the stock pistons were given a clean, looking good.
So I decided to get new rings, new ACL race bearings, new ARP rod bolts, new ARP 2000 mains, Spool crank collar, Spool Billet N1 oil pump gears installed and lastly the OEM water/oil heat exchanger was deleted.
Motor is still stock lol.
Special thanks goes to Matt at Redsun Motorsport & Mechanical for dealing with my bullshit and also pointing out some cock ups with a previous shop that did my crank collar install.
  • Like 6
Spent part of Sunday going through my collection of nuts and bolts from last year. Not fun, also turns out the service manual doesn't tell you of bolt lengths to use lol.
Modified RWD pickup installed, one day this motor could go into a GTR lol.. 0.1L smaller but higher compression, has VCT, billet oil pump gears so it won't go bang!
Installed water pump, ancillary bracket as well as the alternator. Whilst installing the water pump with gasket maker I then rummaged through the box and found a gasket for it lol.. too bad so sad.
Another hiccup was that the Stagea engine mount brackets/arms are no good in the R33 so will need to source RWD ones. Then as I was installing the knock sensors followed by the OEM oil pressure sensor - I realised the NEO uses a different one so derp.. need a R33 one.
  • Like 3
13 hours ago, ActionDan said:
Worth redoing the water pump or you confident in the gasket maker?
Nissan manual advises to use gasket maker, so should be on point.
I really hate putting it together.
I have never used anything but gasket maker. The gasket looks like a piece of a4 paper cut roughly into the shape of a dick anyway, would much prefer liquid gasket
  • Haha 1
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
