No real update to my build thread, because it's a shit build.
Doesn't have the following:
  • Emtron
  • Borg Warner EFR
  • Pierburg Fuel Pumps
  • ID injectors
  • Race Pedigre
Only runs shit parts such as:
  • Haltech (with no additonal boxes)
  • Walbro pumps
  • Bosch Motorsport injectors
In other news, looking for someone to respray the R33 shit box. Not a GT-R so no need for a hectic respray as it will get used on the track. Something of an OEM finish would be great around Sydney, my budget is about $5k but of course happy to pay a little more if able to get the rear guards cut and new slightly wider guards (from a different car or aftermarket) welded on.
I'm around the Cabramatta area, so anything near by would be good. Anyone got suggestions? I might pop into 2SUS for a chat and use that as a starting point/benchmark.
  • Haha 1
13 hours ago, WantGTR said:
pick one on Hollywood Drive brah
Any of your mates used them before? I know there's a few. Some dodgy looking some look half decent.
i used to use Hollywood body repairs years ago when the asian dude owned it. it changed hands and has since shut down i think. Precision Autobody Repairs look like they do good work.
Its not in the area however Bellevue Bodyworks in Carlton do really nice work. A close friend has had his car resot'd there and they have done some small jobs for me in the past. Any further work id definitely be taking it to Bellevue Bodyworks.
Cheers bro! Will go for a drive around a few shops in the shit box in a few weeks and have a chat to all of them. Looks like the R33 might end up looking less of a shit box and looking more like a well maintained dated old car with cheap shit parts on it.
Nothing too exciting, however got the Nz Wiring Trigger kit working. Turns out the Haltech Elite patch loom is wired to only receive the 120 degree input from the CAS. Took me a while to work that out with Matt from Haltech and Geoff from NZ Wiring.
Kudos to both, top dudes!
Some non-interesting footage of the trigger error count & engine running smoothly on the new trigger
  • Like 1
My idea of running smoothly and yours are two different things ?
Whats your arming voltage set to currently? Also i thought geoff was making the swtich to hall effect sensors?
hahaha.. well it's running smoothly enough LOL
I have it roughly as follows:
  •        0 RPM - 0.18volts
  • 1000 RPM - 0.9 volts
  • 2000 RPM - 1.5 volts
  • 3000 RPM - 2.0 volts
  • 4000 RPM - 3.0 volts (onwards is all the same)
** edit
I'll start driving the car around and pull logs so I can get the right arming voltages, also not too sure if Geoff will be moving to a hall effect sensor, the reluctor although "old school" is actually quite reliable
  • Like 1
New alignment ✔
New tyres - Nankang AR-1 in 265/35/18 ✔
New rotors - DBA4600 T3 ✔
New pads - Intima Type-D v2.0 ✔
New buckled guard - ?
Car does drive nicer and relaxed the caster a bit, had 8.5 degrees before which was a bit too extreme. Has 7 degrees now, and less strain on the LCA bushing.
Guard buckled when I was rolling them to get the car to clear the 18x9.5 +20 wheels with 265mm section tyres all round.
  • Like 4
13 minutes ago, ActionDan said:
Should've just bolted on some small flares you spud.
Car is looking good otherwise.
Should have not built the car lol
13 minutes ago, admS15 said:
Have you driven it on the street with those. The noise.. So when is it's maiden voyage to wakefield in it's new improved form.
A little bit yesterday, they seem to be pretty grippy when not even warm and the noise is still much quieter than how the car was before with cooked wheel bearings all round.
Has all new wheels bearings, new traction rods, new ball joints, new alignment so yeah - it's pretty quiet. Should be exciting once it's running properly, just spent all of yesterday night working out why the A/C wasn't triggering and when I earthed the input pin going into the ECU the FICD relay kept clicking and why that pin was actually drawing current. Turns out I didn't connect up the A/C thermister and for whatever reason that affects the entire A/C circuit. I was so tempted to just hook up an AVI into the Haltech and use a flick switch to enable the A/C lol
Race Car life, needs AC
Oh yeah, alignment specs for those wondering
Front
  • 7 degrees of caster
  • 1mm toe out each side
  • -2.5 degrees of camber (turned out that way due to height)
Rear
  • 5mm extended traction rods
  • 0.5mm toe in each side (didn't go 2mm like before, as I'm hoping the traction rods will stop the ramp)
  • -1.5 degrres of camber
  • Like 5
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
