2 hours ago, MBS206 said:
It wasn't a pandemic in 2019 either. Someone said that statement, and how'd that turn out for us?! 😛
In beginning of March 2020 it was still a running joke, mid March it went to shit
Shit box survived all 7 sessions of hooning and circuit.
Didn't get a clean run on any of the sessions as there was a bit of traffic. Camber changes did make a massive difference and ended up going into T1 at 160km/h without the front washing out so happy with that!
Some eFame shots of the shit box.
348604191_1627263241111145_6932192459068028973_n2.thumb.jpg.6601db55192b3c2890b5bedefa7d1def.jpg
347620379_2212839058920237_4999811960215461977_n.thumb.jpg.f40e39d9f4b6dd97ec936f470c74bcf6.jpg
  • Like 5
Just now, ActionDan said:
Racing is all about WOTIF
Guess you better go race again ;)
haha next All Jap Day!
Meanwhile, I'm trying to work out what night I can go attack SMSP again, I am keen on a low 1m50s around the circuit with RS-4 tyres.
I feel that I am happy with how the car handles now, the front camber made a massive difference! Now it's just practice and more of it.
  • Like 3
I'm just glad to see you using the car.
I'm feeling slightly more motivated again, but wont get back to tub work until the XR5 engine is sealed to avoid contaminating it.
1 minute ago, Jasoncauser said:
Sweet, this is why you built it man! Go send it :)
I dont have headlights on the 32 so cant do the night runs :(
I suppose so, I also still hate the car. If someone walked up to me and asked for a straight swap with a M2/3 Comp I would do it in microseconds.
LOL... why aren't there headlights?
It's a bit like that, you see another working car and it gives you a bit more motivation. I did cheat and drop it off at a shop to do all the heavy lifting this time round.
Is that just a refresh on the XR5 OR full build?
The bucket I picked up for $500 with multiple spun bearings so I could try my hand at an engine build and teach the kids. It's just a stock refresh with some added block mod shims between the liners for if someone wants to lean on it harder later.
If it runs it'll cost me easy 5-6k in the end by the time I replace DMF/Clutch setup etc but could end up with a semi cool car to daily then swap/sell off for something else rinse/repeat as I'm sick of driving the 4wd daily.
It's manual, turbo, bucket seats, nice electrics etc and running is hopefully worth more than it cost me.
If it blows up on first start or I dont get it running, I will part it out, go back to Silvia and buy something else to daily (335i? 545i?).
Anyway, learning lots, I think?
  • Like 2
I should add, bad choice for a learning platform, FWD, 5cyl, Euro... not the easiest car to work on at all, it was like 10hrs to remove the entire front subframe with engine/box attached to get the engine out, I am dreading reinstall...
I really should have bought an XR6T or something, shit even an NA one.
  • Like 1
I
Funny story,
it was at the mechanics workshop sitting in the carpark and the drivers glass just fell off, he got it on his security camera lol. and the price of a replacement is just a joke, so we did this
@ActionDan well it is a Volvo afterall lolol
Hopefully home stretch to get it back on the road and dose city.
@Jasoncauser LOL how does a headlight just fall off lolol
Nope, I'm still mic'ing bearings because I "had to be sure" and double check the machine shops work.
That meant buying a mic and learning how to use it and associated tools lol
Oh then there was the 12hrs or so I spent weight matching the piston/rod assemblies because I "had to be sure" and weighed them all and found up to 8g difference....
Could've stopped at 3g like the machine shop said for a street engine, but "had to be sure" and went to 1g....
Shoot me.
  • Like 1
  • Haha 1
Because someone's been in there before you. They are a pain to pull apart from factory, no chance factory goop stopped gooping suddenly
Just now, Duncan said:
Because someone's been in there before you. They are a pain to pull apart from factory, no chance factory gooped stopped gooping suddenly
Yeah we thought the same when we looked at the glass channel lol
we did toy with the idea of putting lights in the panels we made but will just get those Motive headlight ducts down the track
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
