2 hours ago, ActionDan said:
Also what rice body kit bits can we add to the missus Tiguan to make it look less mum spec?
Maxton Designs do small lips and stuff that might suit your aesthetic needs.
Not sure if you got the PFL or FL MK2, just have a look here:
https://www.ausbodyworks.com.au/collections/tiguan
  • Like 1
Oh wow, these actually look quite nice. Might be a bit too subtle and still look mum spec though in my opinion.
What about wheels? I saw a Golf wagon the other day with some fancy rotiforms on it. Very unexpected and it looked great as they transformed the look of the whole car. Though depending on how the car is driven it may result in anguish having them murdered on curbs.
The 20s ride ok, just not with the Continental Contact Sport 5 it comes with. I've replaced them with Pirelli Scorpion Verde and it rides much better, albeit lost cornering grip and straight line traction.
I can blaze the front tyre(s) when I mash the pedal before the Haldex kicks in.
7 hours ago, Dose Pipe Sutututu said:
Won't gutter the wheels as easily too
The country doesn't have gutters. Just huge ditches on the side of the road... 😛
  • Haha 2
I went to a CFA call out, during that wet AF winter, thought I'll put my car off the side of the road to clear the way, woops, too far, dropped in up to the sill on the passenger side immediately, did call out, had a few goes at getting it out (had just switched back to road tyres, no good lol).
Chucked my rear hitch receiver onto the DELP guys car and used my winch to pull the noise back out onto the road lol
Scratched my rims too :(
So yeah, I love those ditches!
  • Sad 1
Sound deadening some more, repaired the OEM mat between the rear seat and boot, covered its mum in sound deadening too.
New Maxi Cosi Titan Pro seat in too, got it for $299 on sale with 2% cash back via Cash Rewards. Brings it down to $293!
  • Like 3
They did ok, when compared to Toyota. Ever seen a Chaser?
Btw.. my sound deadening efforts was worth it. Cabin noise has dropped, once I do the front doors and the roof lining it's going to be 0.01% less shit overall.
  • Like 2
  • Haha 3
1 hour ago, ActionDan said:
Man, R33 interior is iconic to me, mad memories.
The rear floor mats.
Even to this day I reckon are wickedly awesome!
Some days I wish I still had some of that stuff for mine rather than stripped out to be used for track work only. At the time though, someone needed a way to make it less street able so I would keep my license / not die.
The Yaris has the floor mats from my 86
They are the best part of the interior LOL
No more mods, car is done, etc.
So turns out my tiny AF lift pump is still moving enough fuel to pressurise my surge tank and even the fuel rail when both surge pumps are off. I'm getting about 0.55bar of fuel pressure at the rail with the surge pumps off and only the lift pump running.
This means that the OEM venturi/siphon is causing a massive restriction, enough to build that pressure. I've been told it's not too much to be worried about, however the inner efficient Asian that I am says no!
Pressurisation of the surge tank & running the lift pump harder does three things:
  • degrades the surge pumps quicker
  • more load on the electrical system as the surge works harder
  • by product of the above, more heat is generated
  • (possibly point 4) more heat generated means all 3x pumps swim in a warmer fuel soup and degrade faster
So yeah, at some stage I will need to remove that stupid fuel tank lid/hat/cover whatever the fk you want to call it and pop off the OEM venturi/siphon and pop this one on - pretty straight forward really, just massive CBF as I will smell like shit and inhale heaps of petrol in the process.
  • Like 1
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
