No real update to my build thread, because it's a shit build.
Doesn't have the following:
  • Emtron
  • Borg Warner EFR
  • Pierburg Fuel Pumps
  • ID injectors
  • Race Pedigre
Only runs shit parts such as:
  • Haltech (with no additonal boxes)
  • Walbro pumps
  • Bosch Motorsport injectors
In other news, looking for someone to respray the R33 shit box. Not a GT-R so no need for a hectic respray as it will get used on the track. Something of an OEM finish would be great around Sydney, my budget is about $5k but of course happy to pay a little more if able to get the rear guards cut and new slightly wider guards (from a different car or aftermarket) welded on.
I'm around the Cabramatta area, so anything near by would be good. Anyone got suggestions? I might pop into 2SUS for a chat and use that as a starting point/benchmark.
  • Haha 1
13 hours ago, WantGTR said:
pick one on Hollywood Drive brah
Any of your mates used them before? I know there's a few. Some dodgy looking some look half decent.
i used to use Hollywood body repairs years ago when the asian dude owned it. it changed hands and has since shut down i think. Precision Autobody Repairs look like they do good work.
Its not in the area however Bellevue Bodyworks in Carlton do really nice work. A close friend has had his car resot'd there and they have done some small jobs for me in the past. Any further work id definitely be taking it to Bellevue Bodyworks.
Cheers bro! Will go for a drive around a few shops in the shit box in a few weeks and have a chat to all of them. Looks like the R33 might end up looking less of a shit box and looking more like a well maintained dated old car with cheap shit parts on it.
Nothing too exciting, however got the Nz Wiring Trigger kit working. Turns out the Haltech Elite patch loom is wired to only receive the 120 degree input from the CAS. Took me a while to work that out with Matt from Haltech and Geoff from NZ Wiring.
Kudos to both, top dudes!
Some non-interesting footage of the trigger error count & engine running smoothly on the new trigger
  • Like 1
My idea of running smoothly and yours are two different things ?
Whats your arming voltage set to currently? Also i thought geoff was making the swtich to hall effect sensors?
hahaha.. well it's running smoothly enough LOL
I have it roughly as follows:
  •        0 RPM - 0.18volts
  • 1000 RPM - 0.9 volts
  • 2000 RPM - 1.5 volts
  • 3000 RPM - 2.0 volts
  • 4000 RPM - 3.0 volts (onwards is all the same)
** edit
I'll start driving the car around and pull logs so I can get the right arming voltages, also not too sure if Geoff will be moving to a hall effect sensor, the reluctor although "old school" is actually quite reliable
  • Like 1
New alignment ✔
New tyres - Nankang AR-1 in 265/35/18 ✔
New rotors - DBA4600 T3 ✔
New pads - Intima Type-D v2.0 ✔
New buckled guard - ?
Car does drive nicer and relaxed the caster a bit, had 8.5 degrees before which was a bit too extreme. Has 7 degrees now, and less strain on the LCA bushing.
Guard buckled when I was rolling them to get the car to clear the 18x9.5 +20 wheels with 265mm section tyres all round.
  • Like 4
13 minutes ago, ActionDan said:
Should've just bolted on some small flares you spud.
Car is looking good otherwise.
Should have not built the car lol
13 minutes ago, admS15 said:
Have you driven it on the street with those. The noise.. So when is it's maiden voyage to wakefield in it's new improved form.
A little bit yesterday, they seem to be pretty grippy when not even warm and the noise is still much quieter than how the car was before with cooked wheel bearings all round.
Has all new wheels bearings, new traction rods, new ball joints, new alignment so yeah - it's pretty quiet. Should be exciting once it's running properly, just spent all of yesterday night working out why the A/C wasn't triggering and when I earthed the input pin going into the ECU the FICD relay kept clicking and why that pin was actually drawing current. Turns out I didn't connect up the A/C thermister and for whatever reason that affects the entire A/C circuit. I was so tempted to just hook up an AVI into the Haltech and use a flick switch to enable the A/C lol
Race Car life, needs AC
Oh yeah, alignment specs for those wondering
Front
  • 7 degrees of caster
  • 1mm toe out each side
  • -2.5 degrees of camber (turned out that way due to height)
Rear
  • 5mm extended traction rods
  • 0.5mm toe in each side (didn't go 2mm like before, as I'm hoping the traction rods will stop the ramp)
  • -1.5 degrres of camber
  • Like 5
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
