Garage tidy, R, S and N parts
Hi all, having a tidy up, few bits to clear out:
R32 front xmember $50
R32/S13 front lcas $40
R32 4 door upper window trims $80
R32 fuel filler neck $30
R32 fuel boot release cable $75
R32 front strut brace $80
R33 S2 front bumper reo (cut in centre) $50
R33 S2 front bumper and fogs $450
R33 RHS drive shaft $50
R33 PS electric mirror (mint in white) $50
R33 S2 rear tail light garnish (in white) $50
R33 Clutch slave (No leaks) $50
R33 non abs factory hard lines $50
R33 air con condensor $100
R33 RB25DET intake pipe (stock) $50
R33 power steering reservoir $50
R33 engine undertray $75
R33 stock smic $50
R33 engine fan without clutch $30
R33 s1 ecu $50
R33 GTR ATESSA pump $100
R34 GTR starter motor $150
R33/33 GTR gearbox xmember $50
RB bov recirc pipe $30
RB/SR 'B' gearbox crossmember $50
RB26 turbo to block water feed pipes $50
SR20 RWD Powerbond 25% underdrive balancer $150
SR20 ignitor $30
180SX DS headlight frame and motor $30
180SX bonnet liner $30
180SX speedo surround no holes or cracks $80
N15 headlights pair $50
N15 sss grille blue $30
N15 sss 4 brake rotors healthy $50
Oil cooler and relo kit suit R32 GTSt but can go on any RB $300
LS2 MAF $100
Random catch cans $30
Random speedflow fittings $10
Located Lilydale or Campbellfield. Pics available on request.
Cheers,
Mat.
o4oo 558 o3o
https://www.sau.com.au/forums/topic/468352-garage-tidy-r-s-and-n-parts/
  • 1 month later...
  • 3 weeks later...
R33 engine fan SOLD
also have
RB26 Rear turbo inlet duct $50
RB26 turbo water feed lines $50
RB26 Rear main housing $40
RB26 oil pickup $30
RB26 alternator adjusting bracket $30
R33 HKS Super Dragger modified $150
eveything nego
  • Like 1
  • 4 weeks later...
  • 3 weeks later...
