I had a look through the ANDRA rule book for a checklist for what must be done once you run break into the ten second zone (10.999 or quicker).
Let me know if I've missed anything!
+ 1.4 Credentials: Need ANDRA membership and Unlimited Drag Racing Licence (UDL). To get a UDL you need to undergo a medical examination. You can download the forms for these things at the ANDRA site.
+ 1.7 ANDRA Log Books. Need to apply for log books and have a tech inspection on your racecar. You can download the form at the ANDRA site.
+ 2.3 Driveline. A tailshaft loop is required for cars 12.99 or quicker.
+ 2.6 Flywheel Shields/Bellhousings. Required to use a steel or titanum bellhousing or shield according to SFI 4.1 or 9.1. You can use a ballistic blanket instead if there is no commercially available steel bellhousing.
+ 4.6 Parachutes. If your car runs faster than 140 MPH a parachute must be fitted and deployed on each run.
+ 4.7 Roll Cage. Full cage mounted at a minimum of six points (or if faster than 140 MPH).
+ 5.2 Tyres. Quicker than 12.50 you cannot use radial fronts with slicks on the rear.
+ 5.3 Wheels. Must be fitted with open ended wheel nuts.
+ 6.2 Window Nets. Must be fitted between side and top bars on the driver's side.
+ 8.1 Batteries. Require a blue triangle to indicate battery location. If quicker than 11.99 you require a battery isolation switch located in the battery location maker.
+ 9.1 Technical Inspections. Require tech inspection every two years.
+ 10.8 Helmet. Adhering to Australian Standard AS 1698 1974/1988
+ 10.10 Protective Clothing. Require fireproof gloves, shoes, socks and a race suit adhering to one of: SFI 3.2A/5, FIA Norme 1986 or FIA Norme 8856-2000
+ 10.11 Harness. Faster than 130 MPH requires a five point harness with crotch strap. Quicker than 11.99 requires a four point harness.
  • 3 weeks later...
AHEM! :)
Dunno about this quicker than 11.99 bollocks though :(
Clint, dunno if the whole book is online - try www.andra.com.au
Adrian
What exactly is a tailshaft loop?
This is a loop of steel that surrounds the tailshaft in the event that it should break, snap, let go etc and keeps it from digging into the surface of the track and flipping your car many many times :)
Picture this, your tailshaft fails for whatever reason and drops out of the gearbox (or similar) and points straight at the tarmac while you're halfway through your run doing 100mph. All bad.
Adrian
front shaft loops = yes
drive shaft loops = no
Front and tail shafts in GTR's face in the direction of travel and therefore pose a roll-over risk. Drive shafts do not.
Adrian
whats andras standing on split tailshafts though?? it used to be you didnt have to have a loop on a car with a centre bearing, such an a skyline... Oh another interesting point was the harness one obviously they dont enforce this rule very often as there are alot of cars i see competing time and time again without a harness that according to the rule need one!!!
Enforcing of the ANDRA rules at WSID seems to be inconsistent to me.
I got bounced 11/8/2004 for running slicks with radials on the front. I counted several other competitors doing the same thing who were allowed to do so by the same officials who pulled me up for it.
Anyone who runs 11.999 or quicker should have a four point harness, yet there are numerous competitors who break that rule.
On 12/6/2004 I ran against George in HYP10A when he ran 9.355 @ 145.44 MPH yet the car was not fitted with a parachute.
As for needing a tailshaft loop when you run 12.999 or quicker, how many times have the scrutineers jacked your car up to check?
The ANDRA rules are not enforced in a consistent manner by WSID scrutineers or ANDRA officials at the track. I think all the rules make sense and don't complain about any of them. But it's hard to swallow when the rules are enforced inconsistently, especially when you are on the wrong side of that inconsistency!
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
