Custom gauge fit R34 GTT only!
stump_69
 Share
Hey guys,
I've been requested to do a DIY on the gauge install in my GTT. ill try to include as much info as possible!!
BTW i don't take any responsibility for anyone's attempts and if you damage anything you have no one but yourself to blame.
Now, We've all seen setups when the aftermarket gauges are just jammed in, honestly that would drive me up the wall.
To remove the factory gauge cover holder
- pop out center vents located under factory gauges, use a plastic popping tool not a screwdriver. unplug hazard light
- two screws hold the gauge pod in, after undoing these you can lift the unit and you'll find one connector for all three gauges
- on the inside, two screws hold the gauges inside the pod
Once separated this is what you're left with
- Remove the 6 screws on the front to take off the plastic cover
- I cant remember how many screws hold the actual gauges, remove them all
- Now that its separated, this is whats left.
- Next step is to pull the aftermarket gauges apart.
These are shadow (defi copy) 60mm
- Using a tiny flat blade, had to bend out the bezel edge so the face could be removed
Bezel, Glass and gauge pulled apart
60mm gauges are a snug fit, all i did was align, pressure fit all three and hot glue holds it all together
Power, Earth, ACC and Illumination all can be tapped from original harness from memory
To finish it off, i ordered a new plastic face from Nissan. think it was about $40 AUD
Final Assembly!
Enjoy!
Edited by stump_69
  • Like 5
  • 3 weeks later...
  • 2 years later...
  • 2 months later...
@V28VX37
im looking to do the same as you, what did you use for a backing / brace to hold them straight and level, also any glue used  ?
any tips, tricks or info would be awesome man
On 26/06/2019 at 2:29 AM, 25SKY said:
@V28VX37
Hey mate, it's a pretty simple setup really. There's an existing mounting rail that the old TV unit bolted on to - I just made little 'shelf' out of a Bunnings bracket to hook onto that.
I used some cheapo aftermarket gauge pods with the backs cut off, just taped onto that shelf with double-sided tape from memory.
The triple gauge cluster housing then just sits around the whole set of three gauge pods, and luckily the standard gauge cluster holes are just the right size for the Defi gauges.
  • 1 month later...
 Share
    • that is correct to be more precise, this sensor goes to a loom which contains only the flat blade single terminal (to connected to this sensor) and then the connector shown in my first post. This loom is tied up to one of engine hairness
    • This is really sad news to hear and it has taken me a few days to come to grips with the loss of Neil.  Neil was very straight forward and I have always respected his honesty and how he called it how it was.  He was a very knowledgeable man and was always available to provide advice when you needed help to solve a problem because he would have encountered the same issue in the past and could explain how he solved it.  Neil will be missed by many members of the Skyline family.
    • Dropped the car down to my mates shop on the 19th to get it on the dyno. Ran the motor in and dropped the running in oil and filter and filled it up with some engine oil.  Monday arvo I went down and we got a tune in her. Had a fun time trying to get it to hook up on the rollers. We end up having to roll into the throttle, reaching full throttle at around 6k. Made 23psi on gate then tapered off to 20psi up the top and spat out a healthy 700rwhp.  We had a slight voltage issue which was dropping ecu volts to around 11.8v so we called it quits and on Tuesday I went down and ran a couple of new power feeds to the ECU and DBW relays. Have yet to test it as we were trying to get things sent into the ECU from the TCU over CAN. We've now got oil temp, programme switch and gear position. Still working on gearbox speed, but have been told what to do so hopefully that will sort it. Once we've got speed working, we can start setting up the gear shift cuts and do some clutch adaptations in the TCU.  Should have the majority of it setup this week and go over the tune to see how it is now with the new power wire.  Was slack this time, didnt get any full runs as I was watching the TCU data on the laptop. Snapchat-322660241.mp4
    • Not until I googled it, now I remember lol. Seems like it's just to clean it up. But it doesn't stop the leak, I have a leak issue though? Thinking whether I need a new bottle, surely not lol.
