M35 DIY turbo replacement
Hi all,
Apologies for creating a new thread but I can't for the life of me find any DIY threads for replacing a blown turbo on the VQ25.
Funnily enough the threads I have found refer OP to the search function.
I understand a few owners have had to go through this heartache but has anyone documented it for use on this forum?
Keen to grab an M35 and want to research turbo replacement as it's going to need it sometime down the track but sale depends mostly on ease of replacing this critical part.
https://www.sau.com.au/forums/topic/468871-m35-diy-turbo-replacement/
Here is a swap I did over 5 years ago.
https://www.sau.com.au/forums/topic/352166-m35-engine-and-turbo-out/
Its a fun job that I personally would only do once so never again.
Some owners love swapping there turbos out.
  • Like 1
  • 3 weeks later...
Have just been unfortunate enough to have replaced the turbo on my M35. It is definitely diy able but by no means an easy job. Patience is the key. What makes it difficult, is the lack of access to the dump pipe/t3 flange bolts. The bolts are more than likely rusty and fused on. Each bolt takes quite a while to remove because of this.
You will need a jack, stands/ramps or hoist, wd40, inox or penetrine etc to spray the bolts with and let soak overnight (i used chemsearch yield) worked brilliantly. A range of extensions, uni swivels for your ratchet, long spanners, shorty spanners, an obstruction style 14mm spanner helps with dump pipe bolts as well, a 22mm spanner for the 02 sensor. A couple of brake line clamps to clamp the coolant feeds so you don't have to dump the coolant. You may have to make or bend a spanner to remove one of the heat shield bolts or smash it off. You will need to remove the front pipe, brackets, disconnect the gear shifter and then unbolt the gearbox cross member and lower transmission to give you access to dump pipe bolts. If you've removed turbos before you will eventually get there, if you haven't, it's not the car to learn on. Just pay someone else to do it and save yourself the headaches.
lol......after doing about 30 of these I can tell you its a different experience everytime. I think the fastest I ever did one was 5hrs......the slowest was about 18hrs. You could never guess which one was to make you its little b@#ch.....the only thing that was always consistent were the little cuts all over your hands and arms. I ended up with 2 draws of my toolbox that was specific to the NM35 turbo change.
Glad you had fun....and I'm glad I will never touch another NM35 for the rest of my life!
Bullshit you still owe me a turbo change :P
Lol, sounds like fond memories. I wouldn't touch another one either unless it's mine. Believe it or not, no cuts on my hands but elbows took a beating. Definitely the shittest job I've ever done on a car, actually timing belt and supplementary auxiliary drive system on an import diesel Toyota estima was almost just as bad.
P.s I put a used stock turbo in it, may need to be done again soon. I'll bring it over to you[emoji1]
  • 3 weeks later...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
