RB26 issues
Good Afternoon everyone,
I've finally had time to start repairing my GTR. I had a vacuum leak from the intake manifold in the past and have changed all gaskets. Since putting it back together, two issues exist:
I've lost the brake booster
I have a fluctuating idle...When I start the car, it idles and sits at 2000rpm for about 10 seconds, following that it idles between 1300rpm-2000rpm (fluctuates)
I have taken the car to a mechanic and they have tested for leaks with a smoke machine. No leaks were reported.
Does anyone have any experience with these issues or have any ideas as to where I should start?
Thank you, comments much appreciated!
https://www.sau.com.au/forums/topic/468988-rb26-issues/
Hey guys, I've checked to see if the IIRC valve is operating which it seems to be, the plastic chamber is not cracked... I've checked the hoses out of the auxillary valve and they seem to be on tight and in the right location. (I also installed new hoses) Does anyone have any other suggestions as to why the brake booster is not working and a fluctuating idle? Thank you so much in advance
https://www.sau.com.au/forums/topic/468988-rb26-issues/#findComment-7811236
Potential to be 2 seperate issues with many causes. Here's some
Brake booster: Air in the brake system, booster flange issue, one way valve, vacuum leak/air leak
Eratic idle/Idles high: Vacuum leak, fouled Injectors, Idle speed, fouled plugs, ECU setting/s
https://www.sau.com.au/forums/topic/468988-rb26-issues/#findComment-7811247
guys just for an update I've fixed the brake booster issue, the idle now sits at 2100rpm when it starts then hunts between 1500rpm-2100rpm...Could it be an AAC issue? or can anyone else point me in the right direction?
I've driven the car and it drives fine, it's just that idle issue now.
Thanks so much in advance
https://www.sau.com.au/forums/topic/468988-rb26-issues/#findComment-7811896
On 2/17/2017 at 4:34 PM, GTSBoy said:
Vacuum leak still there.
If there is one it's hidden away better than the Nazi gold train, Searched all weekend for it, put a new gasket on the AAC valve and cleaned it, same result
https://www.sau.com.au/forums/topic/468988-rb26-issues/#findComment-7812410
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
