January 2017 - Since moving to Sydney (don't know if I mentioned that?), the horn has been getting quite a workout. With only one of the horns working, I decided to upgrade to a set of Hella Supertones. Wanting to keep the engine bay looking neat, I pulled the fuse box out and upgraded the factory wiring, rather than using the supplied relay. I was unsure about having two bright red horns behind the grill, but they're not actually too visible
February 2017 - I'd being keeping an eye out for a while for a Nismo 320km gauge cluster, but the only ones I could ever find for a reasonable price were the white version, and I much prefer the black. I found one on Yahoo Auctions for a really good price because of a dead tacho, so I grabbed that, did a bit of electrical tinkering, and now it's working perfectly. Since I don't have an Active LSD, I wired up the warning light to the alarm LED, which fits in nicely with my 'keep everything looking stock' theme.
I also modified the gear shift surround to mount the wideband gauge where the cigarette lighter was, as it never gets used. I got a scrap piece of plastic and cut a hole in it to fit the gauge, then used epoxy to stick it on, and drilled some small holes to screw the gauge on. It looks rough as, but it's surprisingly strong, it won't be falling apart any time soon
  • Like 2
A few updates from earlier this month:
After putting up with a crappy battery for quite a few years, I finally replaced it with a nice new Optima yellow top (D51R-T1). I can now leave the car for more than a couple of days, and it will still start, amazing!
Next up, changed my old beaten up front pipe for a new Blitz item, with 70mm inlets to 80mm outlet
And just as exciting as the shiny new front pipe, some shiny new brake line clips. These are the same part as clips for a S14 (46289-15U10)
And last on the list, made a slight modification to the AFR gauge. The LED display was a bit too bright for my liking, so I bought some small sample pieces of window tint and applied that to the clear plastic over the front of the gauge. When the gauge is off, it looks completely black, nice and stealthy
Edited by jimnastic
  • Like 2
On 3/31/2017 at 5:01 PM, Humbla said:
Nice, i have an r33 that's been my daily for 15 years ,mods higher boost. If there looked after they go for a long long time. emoji3.png
Yeah it seems like it'll keep going forever, I hope I'm right! It's had a pretty easy life while I've had it, only occasionally pushed hard on a nice curvy back road here and there
  • Like 1
Been a bit busy recently so I've fallen behind with the updates, but this is pretty close to where it's at now
So far, I've just used what limited knowledge I have of tuning to just keep it running nice and safe, but now that I've got all the performance related bits that I want, it was time for a proper tune. Had the car booked in at Unigroup, where it made 265awkw @ 18psi, not a bad result :D
While it could have made a bit more power, it was being held back by the clutch beginning to slip (an Exedy NSK-7172 OEM replacement, changed a few years ago), and some weakness in the ignition system was starting to show. So at this stage, I'm considering replacing the clutch with a Nismo Coppermix twin plate, and possibly an upgrade to LS2 coils, but neither of these will be happening for a while as I'm quite happy with the power it's making now. I'm happy to hear any suggestions or recommendations if anyone is following along
Since a post without pictures is kind of boring, here's a picture of the engine bay not long after I bought it, and one from a bit more recently (still not current though, will get some new pics soon)
  • Like 8
I've been focusing my attention recently on tidying up the engine bay. There's no way I'll ever be able to get it as clean as I want it, but every little bit counts
While I was in there scrubbing away at everything, I also hit a few bits with some black paint
The bonnet stand
These mounting brackets
The top of the headlights, and the coolant and washer bottles. I actually have new replacement bottles on the way, but I just wanted to see what they look like black
I also got some pictures of a few miscellaneous bits that I hadn't covered previously
The interior. The shifter and handbrake boots looked better when they were new, but I don't like how they've faded. They're on the to do list
I've posted about the wideband before, but I didn't get a picture of the data IO cables, which are run through where the little glass window was in the ash tray
The drivers side window switch wasn't quite working properly, which I think is a common thing on the R33s. With a little bit of fabrication work, I swapped the broken window buttons out for buttons from a Hilux, which seem to feel a lot sturdier
This is just a close up of where I've tucked the injector ballast and boost solenoid plugs back in to the fuse box. Makes this whole area look a lot neater than just leaving the unused plugs hanging out
This is the Nismo dash I bought and fixed, with the aftermarket immobiliser LED connected to the A-LSD light. Nice and factory looking
And finally, I haven't really put up any decent pictures of the car itself, so here's one from the weekend
  • Like 3
  • 3 months later...
Since the last update, my partner and I have moved down to Canberra due to her job, so I've unfortunately had to restrain myself from spending too much money on the GTR until I start working again. I did however receive some parts from Japan that I ordered just before the move.
A (fake) Garage Defend style carbon cooling panel. Couldn't justify the price of a genuine one, as I only wanted it so it would cover all the ugly stuff behind the front grill and lights, but it's surprisingly good quality, just took a bit of persuasion to get it to fit properly
Also received some various bits from Japan, including new coolant overflow and washer bottles
Edited by jimnastic
  • Like 2
Good choice of battery, my 10 year old yellow top has finally given up last week with plenty of warning, pretty impressed with the long life
  • Like 1
  • 5 weeks later...
Thanks for the positive comments, keeping it clean and tidy has been my goal with everything, so I'm glad it comes through in the photos :91_thumbsup:
Recently fitted a GReddy oil filter relocation kit. I avoided doing this for a long time as I really didn't want anything in the engine bay that didn't look stock, but I was a bit over fighting with the location of the filter every time I do a service
Since getting the car tuned, I've been doing some homework on upgrading the ignition system, and decided on an upgrade to R35 GTR coil packs. I got the coil bracket from Platinum Racing Products in Sydney, the coils are Splitfire SF-DIS-103, and the harness was found on ebay. The engine cover is staying off for now, as it will need a bit of modification to clear the rear coil
  • Like 3
  • 4 weeks later...
  • 10 months later...
Things got real busy between now and my last update, bought a house, got married, all of that stuff that keeps you occupied. Very excited to have a garage now, so the GTR finally has a roof over it's head, and I've got plenty of room for bigger projects (possibly a friend for the GTR soon?)
Anyway, here's a small update to start things off - New handbrake and shifter boots. Bought these from redlinegoods.com, very happy with the quality of these compared to the cheaper ebay ones I had before, hopefully they hold up a bit better
  • Like 2
As mentioned earlier, the clutch was a bit unhappy with the new tune. Coppermix twin plate was purchased along with a few other bits to change while the gearbox is out (parts breakdown in an upcoming post)
IMG_20180117_161133.thumb.jpg.6e6125f3f0ee72888af857242f4e0695.jpgIMG_20180117_162123.thumb.jpg.c144623c3126674c9f2105323a7c68cf.jpg
Rear camber arms from Hardrace to hopefully stop the rear end from eating tyres
Found this stock stereo going for a good price. Planning to install a bluetooth module and replace the existing JVC unit
  • Like 1
Minor update between buying the clutch and fitting the clutch
Got these Behrman replacement headlight lenses from rhdjapan. Only problem is they're too nice to put on the car. Looking into what options there are to protect them, at this stage thinking of covering them with clear vinyl wrap or something
Here's a little project I've been working on. I've developed this weird obsession with getting the power window switches to feel nicer and work better. Bought a VW window switch, which turned out to be way more complicated than a switch needs to be. Programmed an Arduino to translate input from the switches, and then send that information back to 1995 so the car can understand. Very rough looking prototype installed in the car while I continue tweaking it, but it works... some of the time.
  • Like 1
Wow that's insane!
Yes I must admit all the buttons, switches, resistive door locks gives me a boner each time I drive the Tiguan (and DSG farts lol). Getting into the time machine aka Skyline hurts, until you press the loud pedal :)
Haha similar situation with the wife's Polo. Will take crappy switches and RB soundtrack any day
Also been thinking of doing something to replace the awful headlight/key buzzer sound with that nice VW 'ding ding ding'. Maybe it would be easier to just swap the RB into the VW at this rate
    • Had a chat to Tony Mamo - he advised that looking at the graph's shape (regardless of number translation) it shouldn't be levelling off like that up top. He said it looks like the car is running a restrictor plate or something of that nature. Luckily the last dyno pull on E85 was saved to the PC - So I did a quick trace of Barometric KPA vs Intake manifold pressure, and lo and behold I see a copy of the 'waves' I was seeing on the dyno: I'm not entirely sure how to go about addressing this. It may be worth sacrificing IAT to run a more direct intake for the motor. Though packaging this could be flat out impossible given the constraints of the car. I should have removed the intake pipe to see if this made a difference but looking at this graph I now have something to potentially test in the future and think about. This one is from an old track day log in the OLD setup going through gears on track.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
