FS [SYD]: RB25DET Stock Bottom End, Head (or complete but dissembled) - the lot $400
Hai,
So most of you active SAU people might know, my Edward Lee's (Special Edition) Low KM motor finally exploded - which took out my turbo too. I had this big plan to rebuild it, make it a weapon but a few things in life got in the way so that's not going to happen anymore. Instead I am going to put another used motor in and call it a day.
Engine can come complete, although dissembled or parted as per the prices below. Water pump, timing kit are all under 3 years old and less than 20 000km (so can be easily reused for a cheap rebuild). Also has ARP non-2000 studs.
Cylinders 1 & 6 are cooked.. bores slightly scratched and head has some shrapnel marks.
$400 motor minus hotside, coldside, flywheel, coil packs, all ancillaries not included
OR
$200 head, cams, cam caps, cas, VCT, covers, valves. pretty much complete, no head studs
$200 bottom end, water pump, crank, timing belt, idler/tensioner, knock sensors, sump, blah blah., no water outlet
$100 full set of ARP non-2000 head stud/nuts/washers - torqued once only
Contact: Here or PM
Hope someone buys it, gives me some money to invest in a new used, non Edward Lee' SE motor lol
On 3/18/2017 at 7:04 PM, GeeDog said:
Hi Johnny,
Do you still have the head studs? Pardon my ignorance, but what is "non-2000"?
Just sold them on Friday :(
There is ARP and there's ARP 2000, which is much much stronger. Some people get confused between the two.
Will sell head/bottom end, everything as pictured except the coolant neck, electricals, coldside/hotside/coil packs for $300
BUMP
Take the head (complete with covers) and block (no sump, no pickup, no ancillaries, no water outlet) for $200
Pending pickup tomorrow - prospective buyer only needs a crank but picking up the entire motor lol
So you've got space for mine tomorrow then?
but it booorken lol
and... bottom end is sold..
Head Remaining!
  • Like 1
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
