Evo calipers on 34R
I don't like the gold colour of the standard calipers and as they are chipped and marked I had been considering painting them red. I was looking around for some pre-done ones for a nice easy swap and came across threads talking about Evo 7 - 10 calipers being better and using a bigger rotor - and given the price, might be a fairly neutral cost swap plus I can take my time freshening them up before they go on.
Just trying to work out which calipers and rotors are the easiest fit as there seems to be some size differences and talk of adapters/drilling hubs etc.
My car already has 2 piece rotors up front, but I'm happy to buy new ones if the rotor size is bigger on the Evo. Are the rears any different?
Edited by ActionDan
added info
https://www.sau.com.au/forums/topic/469616-evo-calipers-on-34r/
Rears are same.
There's a little difference between 7-9 and the 10s rotor caliper combo.
There are quite a few discussions. Is this just for the efames?
Evo rotor is 320mm. 10 is 350mm
GTR rotor is 324mm
https://www.sau.com.au/forums/topic/438677-evo-brembos-onto-gtr/
Doesn't answer all questions and was relating to 33R, I wasn't sure if they are identical between the models.
So the Evo 9 rotor is actually smaller diameter but thicker, is the benefit in the caliper itself being better then? I see they use an external hard line between sides.
Are you saying rear is the same between GTR and Evo or rear is the same between all Evo models?
I'm assuming adapter is needed for Evo X calipers and rotors, is it also needed for Evo 9 calipers and rotors (if there's any upgrade in that). I can see hat height is different, so assuming a bracket is needed.
What's "efames"?
Edit: Nevermind: https://www.urbandictionary.com/define.php?term=E-FAME and yes definitely in it for fame. I will cross post to Facebook later for more.
Edited by ActionDan
  • Like 1
Found this table on the AlphaOmega site for anyone else - scroll right down like I should have.
http://alphaomegaracing.com/p/119/c/73/Z33/ALPHA-OMEGA/Evo-350mm-Brembo-Front-Brake-Adapter-Kit-Version-3.html
1 hour ago, iruvyouskyrine said:
Let me know if you are looking to offload your current calipers/rotors
Seduced by the big calipers on the Evo X on the weekend?
Do you have trouble pulling up now - or just want to fill the wheel-well a bit more?
I have to say, the brembos on mine never fill me with confidence...not compared to my old bugeye wrx sti anyway..Feel like I have to really stamp on them for anything to happen, and not a lot of feel...wooden feeling - but they do seem to stop...so maybe its in my head. Could just be shitty pads for me too..
Apart from Evo X - R35 brakes are an option too I think..but not sure on master cylinder requirements/changes either.
Will do
Nah not seduced and nah not looking to fill the rim more, purely an exercise in cost effective options.
Car has no trouble pulling up now and was able to do a good 5 hot laps at winton without issue (ferodo pads and 2 piece rotors) it was only when I did a couple 8 lap stints they got a bit hot and I ate into the rotor a little.
It won't be tracked like that again, maybe a logic day or something, so I don't "need" bigger brakes.
If I want red calipers anyway, and Evo calipers are not only cheap, but better than mine, nothing to lose by swapping given I can cover the cost selling my current ones and ed up with better calipers, bigger rotors, and will be fresh and red like I want.
35 brakes 3-5 times more exensive
2 hours ago, Hadouken said:
Wrong, but why would that matter anyway lol
Cheapest and fastest way to get the "look" would be just to paint the current caliper. If I'm gonna pull calipers off, I might as well see what cheapo upgrades are around. Same thing I do with every other mod, which is why the Silvia has so many new parts everywhere - pull one thing off, replace/restore everything around it and don't do the labour again.
This is a middle ground, still cheap, no rush on caliper restoration as they are already off the car, and end up with better brakes as a bonus for minimal outlay.
Fitted splitter, rear spoiler, painted bonnet, guards, bumper, and boot lid, powdered coated wheels, changed hoses in engine bay, painted shit in engine bay, bought hard pipes and customised then painted for engine bay, bought fancy fasteners, radiator guide, etc etc, all for looks primarily lol
Hardly the first time I've wanted to spend time or money to get the type of look I want.
I know the Evo gang is too cool to care so I won't tell anyone you were here in this efames thread :D
It's like you didn't​ even read my post, just replied as fast as possible lol
I'll copy paste the relevant slab of text again, plus will push my post count up #sickbro
"Cheapest and fastest way to get the "look" would be just to paint the current caliper. If I'm gonna pull calipers off, I might as well see what cheapo upgrades are around. Same thing I do with every other mod.
This is a middle ground, still cheap, no rush on caliper restoration as they are already off the car, and end up with better brakes as a bonus for minimal outlay."
After I've sold my front setup the change over is minimal to me given i I get all new hardware (assuming rebuilt calipers and new rotors) and better brakes and who doesn't like that?
Don't worry, I'm not gonna show up to the meets or track days and pretend I'm cool because i have Evo parts, it will be our secret.
Edit: woops not to you Rob, you managed to sleaze that post in there while i was typing on the shitter :D
  • Like 1
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
