R33 GTR 1000HP Parts
Hi guys, parting out my R33 GTR 1000HP street car. Basically everything is up for sale. All parts have done no more than 5000 street kms and dyno runs.
Reason for selling as ive been EPA'd.. again and i keep losing my license, and being a mobile mechanic is shit with no license lol
Have deposits on os88 gearbox and clutch
Also deposit on RB30 3.2 nitto bottom end and 26 head, if it falls through will advertise.
Parts for sale:
Plazmaman GTR intercooler, 4 inch outlets and 100mm. Good for 1500hp. Asking $1200 ono
1300hp CDI ignition system kit from hi octane, which includes everything, Asking $2000 ono
Motec M800 Asking $3000 ono
ARC 4 inch titanium exhaust from dump, Asking $2500 ono
HKS oil cooler kit, Asking $1000 ono
Hypertune single throttle body intake manifold and 100mm hypertune throttle body, Asking $2000 ono
Genuine ID2000cc injectors x6 and fuel rail, Asking $1250 ono
Two 45mm turbosmart gates with 14psi springs, Asking $600 ono
Custom made 26/30 twin pulse, twin gate exhaust maifold to suit gtx4294 top mount, Asking $600 ono
GTX4294 with 1.01 rear housing, Asking $1500 ono
Two 044 fuel pumps and surge tank, Asking $300
Ross balancer and trigger kit, Asking $750 ono
Quiafe front and rear differentials, Asking $3000 ono
Tein Coilovers, Asking $1000 ono
Probs a few more items to mention that ive forgotten, if you want photo's or have any questions, feel free to contact me on here or my mobile, 0423 756 123
All parts still in car, will remove all most likely this weekend.
Cheers, Christian
https://www.sau.com.au/forums/topic/469619-r33-gtr-1000hp-parts/
Still for sale
Motec m800
CDI ignition system
HKS oil cooler kit
Plazmaman intercooler Pro series twin entry 4inch outlets
ID2000cc injectors x6 with fuel rail
Twin 044 pumps with surge tank
Eboost street boost electronic boost controller series 1 $250
Its the full cam and crank trigger kit, 12 teeth. I forgot to mention it is to suit rb30 bottom end as the crank sensor has been shaved back to fit my setup. You can get it to fit 26 bottom end just need a small spacer to raise the height back to standard.
  • 3 weeks later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
