That's the car I started this topic about. I was VERY interested in the car until I saw that grading. No matter how good the inspection results where I feel that its way over priced with a R grading. What I couldn't understand is why it received the grading but had no noted panel repairs on the auction sheet. Did you receive a Japanese history check on the car? I got an auction sheet from heartbeart and wasn't sure if it was doctored or not. I too was confused with the meaning of the grading and it was enough to put me off.
jaysevu - I didn't mate, like you i backed off completely when i saw the grading. I made contact with another importer i know and asked him what his thoughts were. He came back and gave me an overview of what he found out about the vehicle. When it was imported the car left with 17" BBS wheels and an electronic boost controller fitted; both of which are no longer fitted to the vehicle. He was also under the impression that the car had been hit in the rear and repaired however i was told by the seller something different.
Im not too concerned about the repairs, provided they have done a good job then that all that really matters. My biggest issue is the grading, although it may have only been a minor repair i think its enough to scare off potential sellers in the future.....
Hi Guys,
I have no vested interest in the car either way but I did look at it for another forum member.
I ran my paint thickness gauge over the entire car and the only paint anomaly I could find was the passenger front guard.
For the bonnet and door not to have been painted suggests the damage would have been minor.
It did have correct books and documentation. N1 headlights, Oil cooler and relocation kit.
A grade 4B car other than the guard repair.
I hope this helps.
Cheers,
Bob.
Did he elaborate on why he believed it had been hit in the rear? In regards to the repainted panels the seller did confirm the front left guard had received paint and also the bonnet which is why it received the RA grading. If that was the only repair (repainted panels) then I would have thought id would have got a 4 grade with XX marked on the bonnet and guard so I'm assuming there was more too it and there are some signs of further damage repaired.
  • 3 weeks later...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
