Hi all, I've got my blown RB25DET Neo stock bottom end for sale:
  • Cylinders 3, 5 and 6 have lost compression and it appears that the rings are fused, however still rotates
  • Two of the bores (5 and 6) are scratched deep enough to feel when you run your finger over the bore, there are less severe scratches on other cylinders too
  • When the engine went it first started pushing a lot of coolant and finally went up heaps in crank case pressure and started blowing oil and smoke from the breathers
  • There are some burn marks near the water galleries on the recently changed head gasket (Oct 2016, included with the engine) but we're not sure if these were there before, during or after the bottom end went
  • I am not 100% certain of the root cause of the engine failure and there may be other damage to the block besides the bores
This engine is off my 1998 R34 GTT sedan and was at 156,565km when pulled out, with the last 30,000 kms at around 275rwkw. The car was still movable when the engine was pulled but ran quite rough. Please let me know if you need any other information.
The engine is currently at my mechanic in Melbourne south east, pick up only.
What's included: Engine block, rotating assembly, head gasket, couple of other random gaskets. Possibly sump and oil pickup. I will keep the water pump.
Asking $150 but open to offers. Note I will need buyer's driver license number for the receipt. Absolutely no warranty other than this might make a very awkward coffee table :)
Thanks guys
  • Like 1
$100 if you come and pick it this weekend or next week, I need the space back.
I will even leave the sump and oil pick up on for you, so it should be good for those, crank, rods, engine mount brackets and perhaps the oil pump.
Neo goodness cheap cheap!
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
