EOI: R32 GTR Heated Mirrors, Wiring Harness & Window Switch
I have a pair of factory optioned heated R32 GTR Mirrors in black. Comes with door wiring harness, drivers side switch panel & both mirrors.
Happy to ship at buyers expensive, otherwise pickup from Revesby (Sydney, NSW)
EOI only at this point. $500 (Photo of actual items coming soon)
17353491_10155612228390400_378768409352596631_n.jpg.a47fc58dd708f4c829a4367c05abc58f.jpg
17362852_10155612228375400_7071128753658424624_n.jpg.3cc7fe5dfcfb5684c9c024da36adf08d.jpg
17353401_10155612228385400_6009274468092930764_n.jpg.c58e6e4c8f317c4570e3029001b384db.jpg
  • 1 year later...
1 hour ago, Cazzo said:
@jmknights93 How much just for the switch?
I'd be comfortable with $200 plus postage? I've only seen one other switch online for a similar price tag.
Pass thanks mate. Wrecker has a complete switch available with window switches, surround etc for $120.
Yeah but that's not the same as the one I have hence the price difference...
Nah man, heated mirror type same as yours and it comes with window switches which I don't need. All good anyway.
  • 1 year later...
Just realized that when you asked you were only after the switch and not the surround... my bad...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
