That's an expensive set of nice wheels. Don't spoil it by putting stupidly narrow stretched tyres like some people do!
Something like 285 35 may do the job. If the tyres stick out too much make the guards bigger don't shrink the tyres!
  • Like 6
https://www.sau.com.au/forums/topic/469878-19x105-te37sl/#findComment-7821762
I ran 275x35x19 on my R34 GTR (work d9r 19 x 10.5 +15), which is mildly lowered. I couldn't go full lock without scrubbing on the inner guard linings on both sides.
I went down to a 275x30x19 tyre and used a heat gun on my inner linings. No scrub whatsoever now.
  • Like 2
https://www.sau.com.au/forums/topic/469878-19x105-te37sl/#findComment-7822513
9 minutes ago, OV33RR said:
275/35r19 there pretty big dont think id like to go bigger scrubbing as it is
I understand - but then why go 10.5 wide if your not going to put the appropriate tire on there.
The below is 10 wide with a 285 - see how the sidewall is square - surely that will give the car better turning and handling - please someone correct me if I'm wrong.
  • Like 4
https://www.sau.com.au/forums/topic/469878-19x105-te37sl/#findComment-7824201
  • 2 months later...
16 hours ago, vxsr33 said:
From what i have read 275 or 285 is the recommended width for a 10.5 inch rim. 275 on a 9 inch rim isn't recommended as its too wide.
275 on 9in wheels are within the LVTA guidelines but the proof of the pudding is in the photos - OPs tyres are clearly stretched and the above 285s on 10 in wheels look just right.
https://www.sau.com.au/forums/topic/469878-19x105-te37sl/#findComment-7838260
  • 3 weeks later...
I've got the same wheels offset etc, previously I had 275/30 no scrubbing now I have 275/35 19's nitto nt05 scrub the inner and outer guard. Then again mine isn't ride height, I wouldn't go anything thicker then the 30 series unless u want to do some suspension and camber work. My front is at 3 degrees camber to prevent my guards ripping again.
https://www.sau.com.au/forums/topic/469878-19x105-te37sl/#findComment-7841048
    • EMU Classic. For what I need it to do I see no reason to upgrade. Link and Haltech would both cost an extra chunk of money for a lot of unutilized features
