Hi all,
I'm making around 250rwkw in my r33 gtst with a hypergear op6 highflow.
My exhaust of right (3 inch system) now is a bellmouth dump pipe, to venom 100cell cat, then straight to a jasma cannon. However the jasma cannon reduces to around 2.5 inch.
This setup is fairly loud but not too bad when cruising and light throttle.
I want to replace the cannon with a piece of 4 inch straight pipe. Mainly because i want to remove the 2.5 inch restriction, i like the look and i can do it fairly cheap. I don't want the exhaust to be insanely loud or drone heaps. A little louder than now is ok.
If i install a hot dog resonator after the cat, will this be enough to reduce noise a bit and keep drone down? Or will i have to install a different type of muffler?
https://www.sau.com.au/forums/topic/469953-exhaust-system-help/
'zactly.  There is a logical limit to how big a muffler under the floor can be.  You obviously need 3" in and out, and it is quite likely that you will need it to be centre-centre because it will be going in in place of a piece of straight pipe.  So your typical oval mid muffle will only be so tall and so-so wide.  Your main degree of freedom is the length, and there will only be so much freedom there.  Get the longest one in the catalogue.
I just checked my exhaust and the way its the piping goes doesnt allow space for a mid muffler.
I also drove the car with a straight pipe (was doing hicas delete so had to drop rear exhaust) just to see how loud it was. Needless to say its unbearingly loud, i got about 20 angry looks even though i drove around at low rpms.
Can anyone recommend me a rear muffler ( preferably dual tip ) that flows well but is quiet?
http://www.smb.net.au/ovalmufflers.htm
They will do a twin tip if you ask
I added a photo of a single tip, 4 inch offset in, centre out for reference. Can be made I any length you want.
  • Like 1
Or leave it as is. At 250KW you are not going to gain a lot from going to 3in. Save up til you can afford a good muffler.
The main reason i want to change is the drop to 2.5 inch really bugs me and I'm over the look of the cannon.
Not expecting any noticeable performance increase.
  • 1 month later...
And the pipework looks 3 inch while the his exhaust is 3.5 if I'm right?
Was looking at this before but had another idea, joining the end of the chamber the end where it's capped to the actual exhaust (without actually drilling through. Just not sure if it'll still be effective that's all)
Saves the hassle of having to find a way to mount the chamber
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
