Best Holset turbo for R33 Gtst S1?
Title basically says it all Im looking for bolt on to stock If I can as top mount Is way too expensive atm unless someone could give me links to used buy it now top mount turbo manifolds for a reasonable price that work. Im currently trying to get into drifting also have access to yahoo auctions as i'm located in Okinawa currently but im looking for something small that spools fast not looking for super big It just needs to be able to bolt on to stock turbo manifold with relatively no issues. Also If you could give me links for good turbos you find that would be much appreciated!
https://www.sau.com.au/forums/topic/470415-best-holset-turbo-for-r33-gtst-s1/
Find an used hks 2535 on yahoo, and be done with it.
Holset spools relatively quick for their size. The "for their size" part is important because most of them are for 600+ hp which is not "fast spooling" on a RB25.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
