Depends.  -5s, being big turbos, are really working at their best up high in the rev range.  So if you were to take the view that your "best" cams are the ones that work in the same range, then you're looking for longer durations.  270° or maybe even more.  But if you take the view that -5s are a miserable thing that leaves your engine gasping for torque until they come on boost, then you'd choose some smaller cams, maybe 260°, and dial them in to work well below the turbos' optimum range, to try to get them onto boost a fraction earlier.  Either way, pack in as much lift as you can within budgetary limits.
Usage model really helps here.  Street or track?
  • Like 2
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831294
I'm running -5s on e85 (flex setup) with Tomei Type Bs.
They're a bit average on on 98 alone, but e85 really wakes the turbos up, mid range and boost response improved very noticeably from seat of my pants view.
I'm boost limited due to an otherwise high km stock motor, a forged build with more boost would be pretty good thing with this setup IMO.
  • Like 1
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831310
Nice
Do you have a dyno graphic to share ?
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831320
Here is my result, although it's a 2.8 it is using -5 snails. Basic spec is...
- 2.8 (9.0:1 comp)
- -5 huffers
- E85
- Twin 3 inch exhaust
- heavily modified head (Naprec chamber modified, 1.5 mm OS in and out)
- cams are a 260 at 10.85 mm with quite an agro ramp rate. The duration at 50 thou is 232 degree's which is the same as Camtech's baby drop in but with 1.7 mm of lift more.
How hard do you want to rev it?
Where do you want your curve to be strongest?
Whats your tolerance to a lazy bottom end? 2.6/-5's isn't particularly strong sub 5000 RPM.
  • Like 2
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831363
Thought I'd weigh in here my mate has got fully forged engine.. still a 2.6 with new crank forged pistons and rods. Tomei ponscams and 1.8mm head gasket. All supporting work and -5 turbos
Hes currently limited to 6800rpm and 1.2 bar (small boost leak currently too so less than that)
As stated below 4-4500 there ain't much going on in fact it's winding him up now. However the tuner said it's quite a mild tune to let him get used to it and limited rpm cos fresh engine build. He said there's lots to go yet... including 1.6 bar boost
He got some adjustable cams to go in to advance ign a couple degrees but even with that and a map tune and more boost he will still be at the 4000 to 4500 rpm range if I'm lucky.
So to that end hes going with nitrous to help the car in that low and mid range so it takes off like a 3ltr twin turbo diesel taxi lol.
Yep he could go top mount.. New big turbos are mental.. I love em but he wants to keep the twins setup and he got tired of manifolds cracking on him with his gtst... maybe down the line but by then a 35 gtr engine will prob be affordable or the car itself lol!
In the meantime I think nitrous is a good way to go for immediate shunt and power and then at 5000 let the turbos do the work. All told with 1.6 bar the car will see about 600+ bhp so that's pretty crazy then 80bhp nos on top is gonna make things rather cartoony lol.
I've heard ppl scoff.. "uhh nitrous is fake power" ...cant stand that rubbish personally.. if it's installed right and connected up and ecu controlled it's every bit a part of the car as anything else and it's a great way to get rapid power.
Just our 2 pence:)
Ant
  • Like 1
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831426
250 kw at 4000 RPM out of a 2.6 using -5's? You're going to struggle, mate.
Whats the rest of the setup? Head been touched?
* I would STRONGLY suggest not running -5's up around 450 Kw + at the treads. They will not last!
  • Like 3
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831589
Just checked your graph out too what boost are you running? Mate running 1.2 currently it's quick but like your graph there up until 4500 it's a bit dull heh
It's going back in a week or two for 1.6 bar boost and some adjustable pulleys to help advance ign a touch. It's not going to radically change it before 4500 but it'll help.. that's where the nos will make it more amusing heh.
I've heard at 1.6 bar these turbos are just silly making 600+ and some ppl have reported 700 so they seem like good hard working turbos overall. I do miss that low down response tho.
It does seem clear at some point to get top mount... a gen2 gtx3582r or precision 6266 which is the turbo everyone seems to jump on for a gtr but I wonder how a gtx3076r would be because I had one on my ol gtst and it was silly responsive down low and the new ones make 550hp+
I think after that for pure response it's an e85 setup or just look into an rb30 for end grunt.
Just saturday morning musings lol...
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831638
Im after cams too. :) budget is wife got my cards not much!
Stock head n block
98
-5's
19psi
Full 3inch pipes all da way i think
Make 412whp
She start to wake up at 4.5k ish
Want it to spool up earlier but can i get more top end hp ? Can we get two things at once.
Sorry 4 highjack
  • Like 1
https://www.sau.com.au/forums/topic/470585-cams-for-5s/#findComment-7831665
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
