Die$eL's R33 GTS build
Hi all,
I'm Nishan from South Africa. I know this is an Australian forum but it seems you guys are in the know on the Skylines and it's extremely difficult to find anyone here in SA that knows them well.
I've just got myself a 95 R33 GTS. I've always wanted the GTR but after getting the GTS I'm satisfied.
Just the sound of the RB25 puts a smile on my face.
Current mods include: Milltek exhaust, button clutch, manual boost controller, coilovers and 18" mags
The car seems healthy other than:
- clutch master cylinder needs to be refurbed
- small coolant leak from water pump
- there is some weird noise at times. Its difficult to explain. I'm assuming its the power steering pump/system. Will flush and replace the fluid. Any suggestions on how to to this and what fluid to use?
Other than that my to-do list includes:
- machine polish the body as it has lost some of its lustre
- oil service
- coolant flush and replace (will do when i'm repairing the leak)
- replace diff oil
- replace gearbox oil
- replace fuel filter
- remove the super dark window tint and replace with a light grey/black
- check and clean spark plugs
- check and clean brake system
- chassis clean
- grease axle, U-Joints etc.
- engine bay cleanup and tidy
- polish intake manifold
- strip and clean entire air intake system including ISCV, MAF etc.
- restore the headlights
- replace rear tyres
- replace cam belt and all the bits that go with it.
What I"ve done to date:
- the car is currently at the mac to refurb the clutch master cylinder. He is having issues getting the correct size plungers etc. Its really difficult sourcing parts for this car in SA
- fitted a battery isolator as I won't be driving the car daily and want to save the battery
- did a quick engine wash. I only had about a 1/4 bottle of engine degreaser. will do a proper wash when the car is back
I'm a big fan of preventative maintenance. Is there anything else that I should be giving attention to?
https://www.sau.com.au/forums/topic/470812-dieels-r33-gts-build/
Progress updates in italics.
- clutch master cylinder needs to be refurbed - stripped it, tried to get new seals but could not so reassembled it. Clutch does seem better now but not perfect.
- small coolant leak from water pump - bought a new one but it's in cape town (over 1000kms away). Just need to get it shipped up to me.
- machine polish the body as it has lost some of its lustre - Did a hand polish and there is a Huge difference. Will get it clayed and detailed once the pressing issues are sorted.
- oil service - Done!
- check and clean spark plugs - Done
- check and clean brake system - Checked but did not clean yet.
- replace rear tyres - Done
- engine bay cleanup and tidy - Partly done. Still lots more to do
- strip and clean entire air intake system including ISCV, MAF etc.- Started. I've cleaned part of the intake system and the MAF. I've never seen a MAF that dirty. Previously the fumes off the car made your eyes burn and there was a strong fuel smell. This is now sorted after I cleaned the MAF.
- restore the headlights - They were polished along with the car and are Much better. Still need to do another polish on them though.
The speedometer was not working. I found a plastic wire connector from the speed sender on the gearbox that broke and was undone. Zip tied it together and now I know by how much i'm exceeding the speed limit.
I also fiddled with the manual boost controller and got it boosting at 0.75bar (11psi). I believe this is still safe on the stock turbo.
Still to do:
- replace diff oil
- chassis clean
- the dash surrounds around the radio etc have been plastidipped and bits are worn. I will be pulling it off, cleaning it up and recoating it.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
