Opinions for Porting Factory Manifolds to Support Garrett -9s
My engine is out and while it's out, I'm pondering how much to port the factory exhaust manifolds.
I want good responding characteristics and reliability, and I don't care for top end output.  So I get the Garrett -9s and pair them with Tomei Poncam Type A and Tomei dumps.  My factory exhaust ports measured at 38mm x 41mm, and I know OEM N1s are 38mm x 47mm.
I am thinking just 2mm and make them 38mm x 43mm, so it doesn't lag too much at the low end.  I know this is perhaps unnecessary minutia, but I still appreciate your opinions!
I would, and I did.... just match the profile of the turbo, no more no less.
Would also recommend if you haven't already, ceramic coating the hotside from manifolds to front pipes while your there.
  • Like 1
Are you also running Garrett -9s?  If so, at what psi/bar are you running, and at what rpm does it reach full boost?
My car cam with Tomei Expreme manifolds, which I removed when I went to -9s and I used N1 manifolds instead as they are cast (so no risk of cracks) and slightly larger than the stock manifolds, but not as big as the Tomei's. Best of both worlds.
Don't port them for power, port them for response/smooth gas flow. As was said stock manifolds flow plenty for a -9 turbine housing.
Oh and if you want ultimate response get rid of the Tomei cams and get some cam gears only.
The best you will achieve with aftermarket off the shelf cams is almost matching response and better top end.
The only way you will get better response from a cam is a custom job with mad lift and no extra duration.
I have kelford L182A (with -9s, N1 manifolds, big dumps and exhaust and e85) and we basically matched response but with much more mid range and top end grunt.
I will also add, and this is an unpopular opinion, if you want response and are going to run the -9s at higher boost, get pods.
I gained 14rwkw and response was better moving away from the factory 34 airbox and apexi panel.
Just intake cam gear or both intake and exhaust cam gears?  And at what degree would you suggest?
Port matching is also being considered, as I'm curious if the exhaust air exits manifold into turbine housing would result in turbulence because of the different size.
Yeah I believe pods would give performance gain across range, but they are just a bit unsightly for me.  I did get the HKS panel filter though, unnecessary expensive for a flat piece of sponge. lol
Both gears and get them adjusted on the dyno. Usually it's a few degrees advanced on the intake and a few retarded on the exhaust.
Port matching is fine, just don't open the ports too much.
Get a pod box.
  • 4 weeks later...
I left the factory manifolds as they are.  But I'm still really struggling if I made the right decision...
How much of a top end loss should I expect without port matching?  And how much of a lag should I expect if I do?
Engine is still out waiting to get intake plenum back from powder coating, so there is still a chance to reverse course!
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
