Opinions for Porting Factory Manifolds to Support Garrett -9s
My engine is out and while it's out, I'm pondering how much to port the factory exhaust manifolds.
I want good responding characteristics and reliability, and I don't care for top end output.  So I get the Garrett -9s and pair them with Tomei Poncam Type A and Tomei dumps.  My factory exhaust ports measured at 38mm x 41mm, and I know OEM N1s are 38mm x 47mm.
I am thinking just 2mm and make them 38mm x 43mm, so it doesn't lag too much at the low end.  I know this is perhaps unnecessary minutia, but I still appreciate your opinions!
I would, and I did.... just match the profile of the turbo, no more no less.
Would also recommend if you haven't already, ceramic coating the hotside from manifolds to front pipes while your there.
  • Like 1
Are you also running Garrett -9s?  If so, at what psi/bar are you running, and at what rpm does it reach full boost?
My car cam with Tomei Expreme manifolds, which I removed when I went to -9s and I used N1 manifolds instead as they are cast (so no risk of cracks) and slightly larger than the stock manifolds, but not as big as the Tomei's. Best of both worlds.
Don't port them for power, port them for response/smooth gas flow. As was said stock manifolds flow plenty for a -9 turbine housing.
Oh and if you want ultimate response get rid of the Tomei cams and get some cam gears only.
The best you will achieve with aftermarket off the shelf cams is almost matching response and better top end.
The only way you will get better response from a cam is a custom job with mad lift and no extra duration.
I have kelford L182A (with -9s, N1 manifolds, big dumps and exhaust and e85) and we basically matched response but with much more mid range and top end grunt.
I will also add, and this is an unpopular opinion, if you want response and are going to run the -9s at higher boost, get pods.
I gained 14rwkw and response was better moving away from the factory 34 airbox and apexi panel.
Just intake cam gear or both intake and exhaust cam gears?  And at what degree would you suggest?
Port matching is also being considered, as I'm curious if the exhaust air exits manifold into turbine housing would result in turbulence because of the different size.
Yeah I believe pods would give performance gain across range, but they are just a bit unsightly for me.  I did get the HKS panel filter though, unnecessary expensive for a flat piece of sponge. lol
Both gears and get them adjusted on the dyno. Usually it's a few degrees advanced on the intake and a few retarded on the exhaust.
Port matching is fine, just don't open the ports too much.
Get a pod box.
  • 4 weeks later...
I left the factory manifolds as they are.  But I'm still really struggling if I made the right decision...
How much of a top end loss should I expect without port matching?  And how much of a lag should I expect if I do?
Engine is still out waiting to get intake plenum back from powder coating, so there is still a chance to reverse course!
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
