On 01/09/2017 at 9:45 PM, fatz said:
Over the period of 10 years I have got about 20 slabs and had my trailer rebuilt 3 times by people borrowing it
dont lend trailers
This!
Since buying a new trailer I've never loaned it out and have no intention to. Previous trailer was damaged each time someone borrowed it. People have no respect for others' property.
I hear this alot. I guess it depends who you lend it to.
A mate bought himself a newish trailer recently and is very selective about who uses it.
If he doesn't like their style he just says no, simple as that.
  • 2 months later...
A decent tilt trailer is 3-5k.
Borrowing the neighbors costs me $40-50. At the local track here's a spot to get it on and off without the extra ramps.
Reckon I can hold out a bit longer while I'm still able bodied lol
That trailer looks like it weighs a ton but of course it depends on the distances you tow and the load as to how relevant weight is. My 500kg Tilta Trailer is brilliant, solar panel keeps the battery charged, from Qld it's been to PI and Bathurst twice, slight buckle in one alloy wheel after hitting a monster pot hole at speed.
Probably not light, but I've never needed to go more than an hour down the road with it and the Silvia isn't too heavy.
I will say, I had to limit my speed to 100 when I towed the GT-R as it got a little wiggle on above that regardless of where I put it.
Yeh my Cherokee is rock solid towing at any speed including braking down hill, the PB Challenger diesel was a POS compared.  The C's long wheelbase with the rear wheels close to the towing point and generally good dynamics helps a lot.Engine just needs a chip.
Is it the latest one that has all the electrical issues?
For the price difference, gotta say I'm making do just fine with the Terri (free work car).
Though I was thinking about adding a trans cooler when I fit the brake controller for a pending camper purchase.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
