Anyone with a coppermix competition twin plate holding 500kw?
As per title, got a new efr8374 on an rb26 and my current normal coppermix twin Is worn out and no longer doing its job. Will a competition version hold 500awkw?
That's really the most it's going to see with this turbo and its such a friendly twin plate I'm inclined to stay using one.
Intune and Nismo3.2ish both killed C spec coppermixes with the 8374. However, one is a 3.0 and the other is a 3.2. Pete's (the 3.2) nearly lasted a month.
It's more the torque that kills clutches. You may be right behind a 2.6L.
Damn, I hope the Coppermix Twinplate Competition that I just installed in my 8374 equiped R34 will hold then! It's just a 86.5mm/standard stoke Neo though, and RWD, so here's hoping...
Great You can be the guinea pig then! But being rwd you should be fine. They kind of act like a drive line fuse, you don't have that luxury with AWD.
Thanks for the feedback guys.
If 3.2ish managed to get one to hold on his car for a while before killing it, a 2.6 with 15-20% less torque should probably last.
Youre right. The question should  I have been who's making  900+ NM peak torque  a on a coppermix but most people only know their power figure. The plan is to keep the midrange torque In check to keep the gearbox and shafts alive anyway, and I have learnt the hard way that a super strong overkill clutch (RPS carbon) just breaks other stuff in a Evo.
Will have a look at the r3c, but the fact the centre isnt sprung is worrying drivability wise.
Cheers.
Edited by burn4005
I think the 2.6/2.8 guys should be ok. I ran a coppermix for 10 years (35,000 kms), power ranging from 370 rwkw to 470rwkw/800 nm of twist.
I pulled it out only after munching an OS gear set. The plates were just over half worn. It never slipped, never misbehaved and never refreshed or rebuilt. This was with OVER 350 big RPM launches under its belt.
To replace it went an OS88 and an R3C. The driveability is on par to the coppermix. It's definitely NOT a lightswitch it's just the pickup point is lower compared to the high pickup of the coppermix. Apparently there was a design change with the OS R series of clutches at some point, not exactly sure when it was though. Some time before October 2014.
Having said that, GTR_JOEY ran 430 rwkw on a 2.6L using the NON C spec coppermix for years and never had an issue. Only 30 ish wkw difference between the above mentioned 3.0 and 3.2, torque difference is a lot more.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
